0 Members and 100 Guests are viewing this topic.
NickZ
   To make it easier to find Itsu's results, as well as mine, here below are the links to both Itsu's youtube channel, as well as my youtube channel.
   Itsu: https://www.youtube.com/user/itsusable
   Nick Zec:  https://www.youtube.com/channel/UChwfL5U16oZ20H6zuW-LIHg
   I am totally against secrecy, or posting false or incomplete information or schematics, to keep us barking up the wrong tree.
   I have heard that Ruslan will NEVER disclose his secret.
   I will respect the source of that information, unless the person wishes to share that himself.
   Lossless champs circuit, provided by Verpies, below.
   Keep in mind that although Itsu built the circuit correctly, according to directions from Verpies, it had very limited output at the bulbs. Nor was tested to self run.
   Verpies can also explain where that information and schematic came from, as well, if he chooses to do so, again. But, I believe that it came from the William McFreely PDF file, which I've since lost. It dealt with a different subject than energy from the Aether, although I may be wrong, or partially wrong there. Verpies can best further explain it's source and purpose.
NickZ
Quote from: itsu on June 04, 2017, 05:26:54 AM
Zalmoxis,
i have disassebled my Ruslan setup, so cannot run my kacher, but i did that before without any noticeable effect.
You will have to search back into this thread to see those results.
Itsu
   Itsu:  I almost cried when I heard that you did that...
  Remember that Akula showed his second self running device able to run even without a ground line. Although not as well, and while overheating the components without the 12v battery nor ground line connected.
   I believe, now,  that T-1000 is correct in saying that no one is totally sharing just exactly how their self running devices are working.
   For fear of the consequences, or due to the loss of monetary gain.  Sad, but possibly true.
   I suppose that it's all up to us now, as it always has been.
   I will however continue to be truthful and impartial in my results, be they positive or negative.
verpies
Quote from: NickZ on June 04, 2017, 09:45:17 AM
I designed this circuit and I drew this schematic.
Actually he had more output at the secondary of a yoke transformer than he wanted.
He experienced a low output out of his grenade coil.
So it seems the component, that determines the magnitude of the output, is the transformer - not this driver circuit.
No, it is a generic driver circuit invented by me to avoid losing the energy contained in the inductive spikes, as heat in dissipative snubbers and instead recycling it back into the power supply.  The spike energy can destroy transistors. This circuit is not a FE circuit but it could be a part of one.
McFreey Modus Operandi relies on shaped orthogonal AC and DC magnetic fields in a spool device containing copper or brass as the gain medium in which beta current is stimulated.  It does not rely on the lossless clamp driver.
itsu
Quote from: lost_bro on June 03, 2017, 03:26:07 PM
Good day all:
Well, I posted my question and then Itsu answered it before I made the post.......
so Itsu, the remaining question is,  seeing that you used the tracking gen. to get the Resonant frequency for your Grenade configuration:  If you *pulse* the Grenade with *white_noise* or some similar broad spectrum signal, do you get peaks corresponding to the same tracking generator *dips*?
Thanks in advance,
take care, peace
lost_bro
lost_bro,
here i use my old method of determining the resonance frequencies of the grenade.
I have my FG loosly coupled with the grenade by a cliplead wire wrapped 2 turns on the thickest part of the grenade
I sweep the FG in 10s from 10Khz to 10MHz, so we see on the scope this frequency range at 1Mhz /div.
It shows roughly the same dips as with the SA, but now as amplitude peaks at 950Khz, 1.7Mhz and 2.6Mhz.
Moving the FG coupling point has some influence on these peaks, so i consider the SA method the better one.
Regards Itsu
apecore
Quote from: itsu on June 03, 2017, 11:44:05 AM
Hi Ape,
nice setup you have, but still some remarks if you don't mind.
You mention to have to connect the clamp wires reversed and that you might have the wrong schematic.
I doubt there are wrong versions around, so perhaps you can show which diagram you have followed.
The version i know of and which i have successfully followed was shown here:
http://www.overunityresearch.com/index.php?topic=1526.msg33035#msg33035    (use firefox to chrome to show the diagrams).
Another remark is about the used big electrolytic capacitors (i understand you use them as C3 and C4 in the above linked diagram)
They are not good performers at high frequencies, so they should be paralleled by some film like capacitors (i use 10nF silver mica caps)
Finally, the long wires used in your setup.
Both for going to the yoke and also between the MOSFET drivers and MOSFETs.
The extra wiring builds up stray capacitance and inductance causing unwanted oscillations etc.
Keep them as short as possible.
I personnaly fix the drivers to the MOSFET leads by soldering the drivers ground leads directly onto the MOSFET source lead.
Good luck with you experiments.
Itsu
Itsu,
Thanks for the comments.
Improvement is always welcome,  so keep the comments going.
Yes,  thats the same version i have used.
To clarify the connection of the clamp i added a picture... i checked it double, but connecting it as in the circuit, the clamp will effect my gates and both FET's fire at same time.
So it cost me a couple of days trying to improve my push pull circuit ,......but at the end Lost_Bro suggested to reverse the clamp.
So i did and the results you have seen on my vid.
So its not my intention to say Verpies circuit is fault, but maybe or better there must be a explanation why i have a good clamp effect in reversed connection.
Also thanks for the S.A. protocol, again some usefull tips.
As i am analysing lots of grenades these days lately and see a lot of different resonance points in different sorts of grenade configurations.
Even the types which are not regular circulating on forums etc. have potential.
Greetings
