0 Members and 279 Guests are viewing this topic.
apecore
Quote from: T-1000 on June 05, 2017, 06:13:59 AM
Hi all,
In regards to grenade windings, at least Sergey Alexeew and Dniester used additional winding.
Sergey's additional winding was under whole grenade and direction same as L1 and tuned to half frequency of grenade
Dniester additional winding was between L2 and L3 and under inductor(continued from L2 on same direction until middle then other way around for L3).
You might also test  those combintations as well.
Cheers!
T1000,
Usefull information ,.....  can you make a short drawing or some more specific information.
At this moment i don't fully understand how it is configurated.
Also i m running some S.A. test as Itsu explained, so it would be interesting to see what effect these changes will have.
As soon i have your information i will modify a grenade and post the S.A. shots
AlienGrey
Quote from: apecore on June 05, 2017, 06:26:09 AM
T1000,
What winding is that then, the only winding I have seen that looks like one is the one in the Sergey video under L1 regarding the Adrian Guska device, there is a video where he takes the 'device apart I don't see any extra winding in his windings it's on his youtube channel.
AG
T-1000
T1000,
I still have not all details. Just winding direction of extra coil in both cases is same as neighbor layer and the wire length follow same length as L1 in A.S. case and same as L2 in Dniester case. In addition to Dniester winding method the wire from the middle of grenade go straight to end then L3 is made as usual.
In A.S. case he explained only winding direction under L1 and said about that to be tuned to the half wave. Which end go to the L1 I am not sure and is something to find out. And the grenade L1 starts in series to extra winding before going to the ground. Plus one of inductor wires is also going to the ground in his case.
AlienGrey
Quote from: T-1000 on June 05, 2017, 08:17:29 AM
This is a shot off the Sergey device, is this what you mean ?
Hoppy
Nick,
Just to check that both of your mosfets are good, follow this test video: https://www.youtube.com/watch?v=gloikp9t2dA
