0 Members and 233 Guests are viewing this topic.
Quote from: Hoppy on May 30, 2013, 10:27:02 AM
Nick,
Knock-up a Royer oscillator to drive your ferrite yoke. You will only get power out if you put it in.  ;)
Mega Dittos.
Thaelin
   I should probably stay out of this but oh well. Has anyone considered reversing the  connect to the coax? in that most of the uses call for the shield to be ground and signal on inner. Not sure how that would go as I have not even tried it my self.
thay
BTW? Anyone have the pic of Romans circuit that has the values for all the parts visible enough to see? Thought I saved it but then cant find it yet.
MenofFather
Quote from: NickZ on May 29, 2013, 12:10:00 PM
   MenofFather:
   Quote:
   In this video no graund wires or antens. And it work many hus, about ten hours he say in video, that in morning turn of and work... It not possible run from capasitor!
", as turning off the house breakers, will also turn off this effect." He not say that.
" To confirm this effect just turn off the house breakers, as it's due to stray AC running through most everything in ones house." Is not mine divice. If you want get more energy, need better make divice and bigger.        End quote:
  I have made a similar device, and can tell you that it is running on the house wiring stray AC capacitive link.  If the house breakers are turned off the weak red AC bulb will also be turned off. NO antenna, or ground needed.
  I know that it's not your device, but I'm just saying that it is not a free energy device, as it depends on the grid and house wiring stray capacitance to function. That is what I think, as the red bulb is weak and not anywhere near the normal mains output level.  You can try it yourself and see, it does not need an antenna or ground, but it does need to be where is can pick up the AC grid stray capacitance. It will not work if suspended on a string without touching anything.  That is my opinion, and the best test is turning off the house breakers, to see how the device dies.  IF this is not the case, then there is another cause, but first that is what I've already proven in my devices. The test is very easy to do, and no he is not saying that, nor testing what I've mentioned either. That device is not new, nor did he improve on it, after a couple of years. Or did he? And why not?
If you find out something different, please let us know.
I know what not possible get 1 W about energy from house breakers, wifi or something like this. You from that maybe get only 0.01 W. I from monitor radiation or cables radiation get about 0.0001 W. But like his divice I not get something similiar any time. If you get one watt like he, then proof it, show video like in you house lighting 3 W LED bulb  on half voltage. This man say, that this divice is not seccesful, because very hard make ajustments, find needed frenquency, and from temperatures diferents it can losse resonance. He very old make this dvice, but then people begin interesting free energy, then it show this dvice. And in 2013 he speak in skype, to give man more information how build this divice. But this man who build this divece looks not very ineresting free energy, so it not try make better ad better divices of firs versions. But he make many that divices, but not general his work is making this diveces.
MenofFather
Quote from: NickZ on May 29, 2013, 01:18:14 PM
  I'm trying to understand what you mentioned in the quote above.
That the yoke is getting it's 220v power from the inverter (not through the driver circuit?).
And that the 12 and 12 turns coil primary current of 1 to 3 amps, and 220v. Red yoke wire not connected to anything, or is not an important connection. And that the output from the 3 turn coil is about 40 volts, and 8 to 10 amps, going to 5 uF 220v capacitor, then to the red resonator air coil that has about 40 to 100 volts on it, and about 6 to 10 amps. The capacitor can increase the voltage by decreasing the current.  Is this what you mean, so far, or not?  This is the circuit that I am working on now, not other circuits at this time.
  Daly's device was not able to be replicated by Itsu, or any others that I know of.  Maybe it has no secrets, but it was not able to be replicated by any others, yet.
"   That the yoke is getting it's 220v power from the inverter (not through the driver circuit?)." Yes (if driver, you mean signal generator-osciliator..., for fets transistors). Directly from inverter, modulated with mosfets, with hight frenquency.
"  Is this what you mean, so far, or not?" Not understand question. I say how I think.
itsu
Using a FWBR i was now able to shorten out the both (positive) halfs of the sine wave.
Results are not that dramatic as when using only 1 rectify diode.
Going from 40V DC to 121V DC (versus 222V with 1 diode) in the capacitor when hitting the optimum frequency/duty cycle spot.
Diodes used are IDH12SG60C schottky.
No audible vibrations from the transformer heard during tuning (like with the 1 diode setup).
Video: http://www.youtube.com/watch?v=ZOlaLwnWkPw&list=UUdJ2A-075yx9y4bKqu_8Q8A&index=1
Regards Itsu
