0 Members and 321 Guests are viewing this topic.
NickZ
  "In my and your TL494 setup, pins 2 and 13 and 14 and 15 are solidly connected together.
Pin 14 is the internal 5V regulator output, so all those 4 pins should have a solid +5V!!
So i don't understand you are able to read "10v down to 0V" on pin 2, it should have a solid +5V"
   end quote from Itsu.
   Itsu: Yes, that is exactly the problem, I believe.  I'll look into it... as it can vary the voltage on that #2 pin from 10v down to 0v as it drains the 4.7uf cap. There lies the error.
Hmmm... on my board, which works... pins 2, 3, and 15 are connected together, and to nothing else. 14 and 13 are connected together and to the non-ground end of the duty cycle adjust pot.
itsu
TK,
then you probably use the by verpies presented diagram like here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg502495/#msg502495
Nick followed the Stalker / Pinoy_tech presented diagram like here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg507286/#msg507286
Different wiring, same results
Itsu
NickZ
  Actually, is was the Ruslan (Oleg), Stalker, PinoyTech designs combination.  I adopted some of the their ideas.
  I took a little from each one of them for my version of the TL494/Uc4420 yoke Kacher/grenade circuit.
  Maybe it's not good to mix and match...?  We'll see.
  I found late last night that my Pin 2 was not directly nor "solidly" connected to the rest of the other 3 pins, #13,14, and 15 pins. Pin #2 is just connected to the 4.7uf cap positive side, but not to the rest of the group of the 3 other pins.  I'll fix that later today.
Hopefully, that's the problem.
      Well, that WAS the problem. I connected the #2 pin back up to the rest of the three pins of that group, and I now have good clean signals at the fets gates throughout the entire duty cycle and frequency range. Thanks for the help with that, guys.
But the MOSFETs are still getting too hot, like as if there is a short somewhere.  I'll be looking into that later tonight.
   So, one problem solved, but one more to go.
   And just now my PC won't start. Can't win for losing.
AlienGrey
Quote from: itsu on June 17, 2017, 05:32:03 AM
TK,
Itsu
Warning This schematic does not need P2 and C2 and connect pin 1 and 16 of the 494 0 Volts the warning is because the 2 opamps control the same logic you can't have two drivers controlling the same logic IT LOCKS UP !  sorry, Verpies. ;) no offense intended ;)
