0 Members and 317 Guests are viewing this topic.
Hoppy
Quote from: forest on June 24, 2017, 04:20:24 PM
Why ? It's nothing important, pure speculation about hidden batteries in kapanadze green box. We all know that it's not possible, because of older video with the same coil
Not possibe - Really!  ??? Like Alien, I would like to listen to a translation of this video. Hopefully, Wesley will show interest in doing this.
NickZ
   Well, perhaps the Brazilian guy that bought that particular green box device should be the one to ask how well those hidden batteries have worked out. As it looks like they still are working quite well after all these years, from what can be seen on his video.
   Maybe T-1000 can let us know if there is anything new or interesting to be concerned about.
   I find it amazing that the secret can be kept up for as long as it has, from such a simple device made out of junk parts. And that we still don't know who actually built that device up, along with all of Tariel's other much more complicated devices. I'm still betting that it was not TK, nor his son. But, it would be good to know where the idea comes from, in any case.
d3x0r
Hi, LTNS
(afterthought) for the TL;DR it's just a hatchet job on how improbable it is that it works at all.
I gathered that the video was a debunk video rather an informative or you know like encouraging that this is a valid device the speaker speaks clearly enough that auto translate to enlish works pretty well.
0:56 a timeline of the viideos.... the video is 1:19 hour long; and you'd think for an hour we'd get to see the device running, but you would be wrong.  The second half of the movie is completely 'singing about the conspiracy charges' then entered the cafe from (0:27 hour to 1:01) but basically it works 10 minutes after a long setup of digging a hole, saturating the ground, etc... during the first 0:00 to 0:12(hours) is just kapandze explaining the 'legend of the device'.
1:43  there is a car battery 12V which drives a converter DC to AC; and claim is that many times output is present (1kW per bulb) than is avaiable at the input.
2:40(ish) review of if this story is real...
(it might be; but the (circus is not techies) the crowd of investors...)
3:28 - explaining that if they were 1KW at full power, hanging like that would damage the base and the wires they were hanging on.  probably only 60W bulbs.. at full brightness 11 1kw bulbs 'would not survive the retina' :)
but probably only 300W output instead of 10,100
well you get the idea.
@NickZ,  Re your prepackaged inverter; I would have said 'it's only one pole, wouldn't be very good for the push-pull action on the ferrite core' but someone responded after a day or so about that.
NickZ
   If you read the specs of that TL494 board, you'd see that it has both outputs available for the push pull topology.
   Although the single ended output can be controlled to a maximum  of 100% duty cycle, the dual outputs for the push pull is controlable up to the normal 47% duty cycle. As Itsu had mentioned. Which is the same as the regular TL494 chips like the ones that I'm using can provide. It also, has built in dead time, to assure that both fets are not firing at the same time. So, it looks usable for these applications, as far as I can tell, so far.
  The guy that bought the device from TK did not mention anything about the device not working, but is showing it running, instead. If his video was made in Brazil, chances are that it works there as well. Maybe this can be looked into further, or it might be another dead end.
  If I can find that video again, I'll post a link to it. However, he is not disclosing it's secret workings, either.
  Would you? Highly improbable that anyone would. As TK was told to not do so, it's a secret, still.
    "So simple, you'll laugh"...
AlienGrey
Quote from: NickZ on July 05, 2017, 09:18:26 PM
Nick Hi,
the 47% duty cycle thing is because with push pull a push is 0 to 47% and a pull is 47%, if they did 100% they would overlap each other. It's as simple as that. In saying that you only need the pulses each going positive for 47% of its own duty cycle to work! but don't get confused ;) Otherwise, the transistors would be on all the time between them and you would have an electric thermal heater with the both the coils and MOS FETs getting red hot and burning out.
AG
