0 Members and 314 Guests are viewing this topic.
Hoppy
Quote from: AlienGrey on July 06, 2017, 08:53:38 AM
this might help Forest and others'.
  Look Hoppy I don't think they use hidden battery's can I suggest you sling all your junk in the bin but salvage your TL 494 driver and output stage next get some decent ferrite toroids 50 to 70mm in Dia pick some with high permeability and bifilar wind them with 8 +8 turns of something like 18 to 12 swg copper wire Oh and insulate the toroid with good quality tape first then connect a signal generator and a tuning pulse charging cap in series with the cap and sig gen and look on your scope to find where the signal peaks changing the cap as necessary start with a low value and it will charge in blocks it needs to be between 17khz and 26khz 29 and above is far too high, when you have worked out the series cap connect the toroid to the push-pull driver and again find the new peak again it should peak around 17 to 26 khz then connect up the 4 turn winding and cap to the grenade inductor and sample the grenade secondary to see if you can find the peak in the grenade if it's different something isn't in tune and your windings are not right but if the grenade response is flat and your toroid still peeks your in business with that part. If it gives a crazy wave as if it's into Fero resonance even better.
AG
Hi Alien,
A sketch of your setup and staged instrumentation connections would be useful.
Thanks
NickZ
  AG:
  The only way to convince someone of what you think would work is to SHOW it doing so, yourself. As well as any positive results.
Otherwise it's all just talk, and no action. There are reasons why it has not worked, so far, for those using a signal generator to find the sweet spot(s).
   The problem with the method that you describe is, that it has not worked for those that have taken the time to do so. Like with Itsu, as the actual sweet spot is not where the signal generator finds it, once the actual device is all set up. Not to mention what connecting the ground line does to the tuned frequencies.
   The other problem is that once all is said and done, and the device is tuned according to what you think is right, the device still won't self run. Even though there can be some positive results (like in Geo's case), with the sync between the Kacher and the induction circuits. It is not enough to allow for a self runner. As Geo and others have found.
  In any case, it's best prove this for yourself, first, before recommending it to others, and to show your results in a video.
T-1000
Quote from: NickZ on July 06, 2017, 10:19:34 AM
True. When people think they assemble circuit and the rest of magic will be done for them nothing of that happen in the end. Then back to square one about the extra energy from the environment which should flowing in the device. That part should be answered even before trying to build such device...
NickZ
   Here's the video of guy from Brazil, showing some interesting things about the TK device that he purchased. Below.
Although IF it were a 5KW device, it would light the whole room, and could not even be looked at. So, it's possibly only a 1KW self runner, or so.
  If one of us had bought it, the secret would be known. OR, maybe not...
   https://www.youtube.com/watch?v=gSNlf0WmG3g
NickZ
    T:
   The problem has been that none of us are willing to actually go and see TK, Stalker, Adrian, Poma, etz...  And give them some money, enough to have them show the device working , and/or purchase it, like the Brazilian guy has done. He can now do what he wants with it, including selling it to the China, or anyone else, and make a few million dollars from it. Like TK could have done,  IF it really works as shown.  Makes me wonder... why TK, Akula, Poma and others haven't already secretly done so.
Perhaps they have done so. I'm sure the big power companies would purchase it in a blink of an eye,  if only to keep it secret.
