0 Members and 369 Guests are viewing this topic.
NickZ
   And I also like hearing from you, as well. Just re-reminding you of what this thread is all about, as to not distract from it, and to help to keep it focused and on track.
   It's always good to hear your video translations, especially of the non mechanical and non nuclear decay type of devices. As you already know my thoughts concerning those other types of contraptions.
AlienGrey
Quote from: AlienGrey on July 06, 2017, 08:53:38 AM
this might help Forest and others'.
  Look Hoppy I don't think they use hidden battery's can I suggest you sling all your junk in the bin but salvage your TL 494 driver and output stage next get some decent ferrite toroids 50 to 70mm in Dia pick some with high permeability and bifilar wind them with 8 +8 turns of something like 18 to 12 swg copper wire Oh and insulate the toroid with good quality tape first then connect a signal generator and a tuning pulse charging cap in series with the cap and sig gen and look on your scope to find where the signal peaks changing the cap as necessary start with a low value and it will charge in blocks it needs to be between 17khz and 26khz 29 and above is far too high, when you have worked out the series cap connect the toroid to the push-pull driver and again find the new peak again it should peak around 17 to 26 khz then connect up the 4 turn winding and cap to the grenade inductor and sample the grenade secondary to see if you can find the peak in the grenade if it's different something isn't in tune and your windings are not right but if the grenade response is flat and your toroid still peeks your in business with that part. If it gives a crazy wave as if it's into Fero resonance even better.
AG
Thanks for your comments but doing such a video would be very time consuming and i'm assuming you know what you're doing and you have your own components to tune regarding the toroid and grenade should they be wound write !! nothing else ;)
The key here is to find the TRUE resonant frequency of the toroid and the grenade.
AG
stivep
I do not want to contaminate your discussion but  Tariel and others have been dealing with :
1. spark gap
2. plasma
3. high voltage
So there is something that was never I assume  mentioned on this forum.
In plasma physics, an upper hybrid oscillation is a mode of oscillation of a magnetized plasma. It consists of a longitudinal motion of the electrons perpendicular to the magnetic field with the dispersion relation
Any  electrically oscillating signal (AC) when in variably condensed  medium ( plasma, air) should be understood as now electromagnetic  in nature acting as a wave.
So for all of these years I was trying to find direct interaction between  electromagnetic quantum physics based (photonic) energy and Longitudinal one that is very much promising
for us, as it is mechanical  response to a force plasma)
And now there is direct dependency between two of them .
Even proposed by me Electrostatic Pump was using inertial motion of an electrons that was in did motion of mass.
So while  you make  appreciated by all of us practical experiments,
I strongly believe  that learning the process of  fundamental mechanisms  in its consequence  will create guide , a manual - for most of you  as easy as like reading manual for assembly of bookshelf from IKEA.
It took thousands  of years for humanity to invent  a wheel. And now every child can do it.
It was only in the mid-19th century,flush toilet was manufactured for wealthiest.
some links for few of you who care:
https://en.wikipedia.org/wiki/Upper_hybrid_oscillation
https://amostech.com/TechnicalPapers/2012/POSTER/SOTNIKOV.pdf
Kinetic theory of plasma waves  ( do not have to be paid) but opens and last page so you need to go to  first page manually:https://books.google.com/books?id=Che5F-ZdvLQC&pg=PA639&lpg=PA639&dq=Electrostatic+Pump+Theory&source=bl&ots=ZOeDC1m_II&sig=w1ehP7Yv9Awh8KD3PxaeUnzKpVY&hl=en&sa=X&ved=0ahUKEwjkuO7T0vfUAhXDZj4KHffrDQoQ6AEINzAD#v=onepage&q=Electrostatic%20Pump%20Theory&f=false
http://www-pw.physics.uiowa.edu/~dag/publications/1979_IntenseElectrostaticWavesNearTheUpperHybridResonanceFrequency_JGR.pdf
http://www.physics.ucla.edu/plasma-exp/references/publications/PRL/PRA-11-2057-1975.pdf
Acceleration of mass or reverse(photon production) is evidently missing link at very bottom mechanism of both
- electrostatic conversion  and
-electrostatic conversion with electric motor supported conversion mechanism.( such  as Tariel Tent Presentation, Tariel in Germany, Tariel in Turkey for Westel presentation, Tariel in wearhouse Tbilisi presentation for  president  Shevardnadze)
Wesley
NickZ
  More discussions on theory, yet, No tests to prove how these ideas can produce a free energy generator.
  You mentioned, plasma, high voltage, and spark gaps. As if these topics have not been looked into or discussed on this thread. However, those topics have not only been discussed here many times, but ongoing tests may still be conducted by some, as well. Along with Earth ground connections, and such.
  Maybe ask T-1000 how it went when using spark gap, as Akula had suggested that he should try. The simpler or easier route. And how long that spark gap can last in the open air, before being completely burned up.
Perhaps he didn't follow Akula's advice on that subject.
  It seams to me that you are still seeking to understand free energy from the perspective of extraction of energy from preexisting mas. As well as associating photons, electrons, etz... quantum particle physics, which are not "particles", as we know them, at all.
Instead of Aetheric physics, as Tesla has elaborated on.
  There have been no free energy devices based on quantum physics, as yet. So you may still have a long road ahead to reach the free energy goal. Such as when trying to extract use able energy by the Colman type devices. Looks like a dead end, as well.
  There is nothing "free" about burning mass to release energy. Even burning wood from your back yard to heat your house has negative consequences. But, "it doesn't cost anything", so it's free energy, you say.
  We have been burning things up since the cave man era. Maybe it's time to stop burning things in the name of free energy. And to start studying Tesla's ideas of harvesting energy from the Cosmic Soup, and it's invisible Aetheric source.
stivep
NickZ
QuoteMore discussing on theory, yet, No tests to prove how these ideas can produce a free energy generator.
  You mentioned, plasma, high voltage, and spark gaps. As if these topics have not been looked into or discussed on this thread. However, those topics have not only been discussed here many times, but ongoing tests are still being conducted by some, as well.
  Maybe ask T-1000 how it went when using spark gap, as Akula had suggested that he should try. the easier route. And how long that gap lasted before being completely burned up. Perhaps he didn't follow Akula's advice on that subject. Oh well...
  There is nothing "free" about burning mass to release energy. We have been burning things up since the cave man era. Maybe it's time to stop burning things up in the name of free energy. And to start studying Tesla's ideas of harvesting energy from the Cosmic Soup, and it's invisible Aetheric source.
Gush my dear Friend ./..
Electricity is quantum based explained. And only quantum based not any other way  at its  very core.
Your cellphone is based on EM  also quantum based explained and not any other way at its very core
Influential function of amplification/interaction  taking place, between mechanical longitudinal wave and quantum explained photonic processes, was not yet discussed on this forum (to my knowledge)
QuoteNickZ  perspective of extraction of energy from preexisting mass
in a sense it is true.
http://www.jick.net/hr/skept/EMC2/node4.html
That is, one  KILOTON's worth of energy is released in the conversion of 0.04658 grams [46.58 mg] of mass.
Thus a  MEGATON [equivalent to one million tons of TNT or 103 kt] is released in the conversion of 46.58 grams of mass;
and the largest thermonuclear device bomb ever detonated, about 100 megatons' worth, converted some 4.658 kg of mass directly into raw energy.
But you do not have to eat at once all food in the can, leave some of it for later. We humans  convert small amount energy due to transmutation/ disintegration at one time.
Lithuania experiment was based on extraction energy  from  mass due to transmutation.
And in here  Canadian ad Hungarian scientists clearly state ( wording: due to ..high iron loss) https://youtu.be/yAu297FCjcY?t=884
I was silent here for quite a time  no problem Nick ..you a smart guy  do whatever you think  is the best and thank you for your work
Wesley
