0 Members and 385 Guests are viewing this topic.
d3x0r
Quote from: Vortex1 on October 01, 2012, 10:23:08 PM
Are they external power source wires or grounds?
Since one of them goes directly to the AC terminal of the bridge rectifier the other connects to L4 the opposite end of which then goes to the other AC terminal, they can be suspect.
It is disturbing, as it agrees with the schematic, but could also be external power wires.
Anyone have a rotation of the device and positive identification? Do they exit from the braid?
I cannot tell by zooming as resolution is too low.
There is the corner ground connection.  The garden video shows the device in entirety more than the benchtop videos.
http://www.liveinternet.ru/users/edward_lee/post235549906/play
I suppose, he could be using something like phone wire for the ground connection, and have two leads bringing in AC, which would go out the bottom near the ground point it's connected to....
Hoppy
Quote from: d3x0r on October 01, 2012, 11:05:06 PM
I think Ganzha is probably right and we are looking at a fake. IMO it could be something similar to the Aqua2 trick, in this case with the braid acting as the mains neutral and inside, carrying a 'live' conductor going back to the domestic supply in the house. This is like TK used for the Aqua2, a braided cable sheath / hose, not ordinary braided earth strap, as it can be seen to be much wider where its clamped with the earth bolt. Only thin conductors are needed for the low energy flouro lamp. Although, fairly obvious from the coil winding ratios, I have already established that with the rail voltage levels shown on the schematic, insufficient voltage is available from L4 to run the PSU. L4 is most likely carrying the mains live feed through to the bridge rectifier. If this is a fake, then Dally is right on one point - that the earth wire is essential for operation of the device  ;D
I will cease work on this project to let this one play out. T1000 has already advised us to hang fire and wait developments from Dally.
Hoppy
T-1000
Quote from: Ganzha on October 01, 2012, 07:57:04 PM
this is really fake matter :-[
Littering thread with single photo again? Dally provided another photo on 90 degrees, there is your answer to wires.
Hoppy
Quote from: T-1000 on October 02, 2012, 03:41:02 AM
T-1000
I've just looked carefully at photo 08 on Dally's website and it clearly shows the two white wires soldered to a tag which is clamped to the earth braid with a bolt. So, if there was a 'live' mains feed into the board, it was not connected at this point as far as I can see. the braid could still act as a neutral conductor with a 'live' wire entering the board at another point. Both the garden video and work bench videos unfortunately leaves a lot of scope for a hidden wire, so its not surprising that 'fake' is being called.
Hoppy
verpies
They could be, but I think it is too early to look for fakery because we do not have any failed replication attempts yet.
I think it very likely that Dally's device is a PsyOp designed to distract from the real McCoy however not because of ambiguous fuzzy photo interpretations but rather due to the absence of a Gain Medium, which is the success determining feature for me.
Dally device contains an exotic nanosecond pulser based on newly discovered DSRD devices. While it is an exciting project in itself, it is also a promising technique for eliciting energy releasing NMR and EPR in various gain media, as described by McFreey and without the difficult tunning of single frequency systems. (contrastingly, nanopulses consist of dense comb of frequencies).
The objective of this PsyOp would be to associate the nanopulsing technique with failure, effectively discouraging people from building devices using this technique because it is the surest way to stimulate energy release from Gain Media without the tuning difficulties exhibited by schemes such as the Yoke Device.
Also, a month ago somebody posted a link on the Kapanadze thread to video of a Russian inventor, who showed a self-running pulsed device that looked almost like the Dally device but contained a Gain Medium made out of ferrite rings.  The author clearly said at the end of the video "so there are not any doubts, let it be clear, that the device uses a ferrite core" and took the core pieces out of the cylindrical tube.
A week later  a very similar but "coreless" Dally device appeared.
I looked but could not find that video again - but maybe it is still there, buried somewhere.
