0 Members and 290 Guests are viewing this topic.
NickZ
  Well, at least on this thread and its related devices aren't too expensive to replicate. It costs more for the scopes, signal generators, and such, than the actual components and coils to build one of these devices up.
   There are guys that have been financed to continue their tests, such as with Nelson. Who has earned their financial help.
Although his device is a bit different. But, hopefully it will also be able to be upgraded in the near future to produce much higher outputs, which can be used to run cars, bikes, and and possibly even power homes.
  I been able to get some more new fets, and so now I can continue with the tests on my device. I hope that they'll last longer than my last ones did. Those last ones quickly failed without even heating up. First time that has happened, to me.
Anyways, we'll see if the new fets will run cooler, without the overheating problems that I've had previously. As my TL board and fet drivers should be working ok, now.
apecore
Quote from: NickZ on July 08, 2017, 11:42:53 AM
Good day Nickz,
How are your FET's doing at the moment?
If they still being destroyed without getting hot it would be probaly overvoltage @ DRAIN_SOURCE.
I would if i were you mount some bigger caps for the snubber part, if you aint eliminating the spikes out of the primairy Yoke in a different way.
Else you probaly conitning burning up FET's while adjusting the Duty_Cycle .
Don't be shy.............;)
Greetings
NickZ
   We'll see. I may have found another problem at the zeners on the fets, and the way that I had mounted them.
I've not seen any spikes, yet.
   If Stalker was able to make it work with his push pull, I should be able to, also. If I can only follow the schematics.
   He also has his yoke wound differently than mine. All my turns are wound clockwise. His aren't.
  Waiting for your beast grenade at work...
NickZ
  Itsu:
  I tested the frequency output of my TL494/UC board with both my scope as well as with my frequency generator.
The scope read right at or around 1kHz, and comparing the wave form to one from my SG, which also showed lightly less than 1Khz, on its square wave 1kHz setting, (on the SG). So, the highest frequency I can output at the fets gates is 1KHz, or thereabouts.
   At a previous time I remember being able to hear a higher tone, from the device, and I was also able to raise the tone to where I couldn't hear it. Which for me at about 11.500KHz.+  So, it was working at a higher frequency at one point, but not now.
   I'll try another TL494 chip on the IC holder tomorrow and see how it compares to the one I'm running on now.
   I wish that I had paid the extra money for the Texas Instruments brand Tl494 chip. Although they'd probably go up in smoke, just  the same as the cheaper ones do.  Well, you know what I mean...
