0 Members and 341 Guests are viewing this topic.
NickZ
Quote from: dllabarre on May 31, 2013, 03:52:27 PM
NickZ
You don't have an email account?
Yahoo.com gives free email accounts.
DonL
  Great idea, I wonder why I did not think of it.
   Edit:
  Actually I have sent him an e-mail, with some pictures of my version of his replication so far.  We'll see if he answers.
Hoppy
Quote from: NickZ on May 31, 2013, 01:39:09 PM
   Re: 's fuelless generator Kapanadze
Message ROMAN КАРНОУХОВ » 06 Jan 2013, 18:16
  Quote by Akula 0083:
For all experimenters !! I have that or similar WORKING DEVICE LIKE KAPANADZE and working for me a long time. I have warmed house and all domestic devices with active load working on him!!
Make a simple trans 12-220, 24-220, 36-220 how to be at one's ease or how one's have radio parts. Put the trans in the field generated by inductor of a simple induction heater scheme.  To make a tangible result the field must have the force to heat up the metal object which is equal in dimension with trans . This is an observation from my personal experience... take a piece of iron about the same size as our trans and place him in the inductor – turn on induction heater as so speak and if metal warming very quickly, well somewhere about in 120 seconds and if already difficult to keep metal in the hands all will work.
Complexity is in that to make windings of trans on such a way so the current build by inductor don't  hamper the work of the transistors or thyristors  shape  220 volt 50 hertz.
Here do as you want....wind bifilars or if you want put intervening transformer.
        End quote, by Akula
Is Akula saying that the transformer to be placed in the field of the inductor, is the same transformer that is powering the inductor?
verpies
Quote from: T-1000 on May 31, 2013, 11:49:21 AM
Just when you introduce diode bridge before coil shorting it introduces up to hundreds ohms resistance in front so something else is needed to avoid this.
It's not that bad.
A full wave bridge rectifier (FWBR) introduces only two times more effective resistance than a single diode in series with the switch S2. (referring to Diag.1 and Diag.2 below)
FOR EXAMPLE:
At 1 Amp the effective resistance of one plain diode is 0.6Ω and a FWBR, made out of 4 diodes like that, has an effective resistance of twice that - which is 1.2Ω.
At 10 Amps the effective resistances of a plain diode and a FWBR are 0.06Ω and 0.12Ω, respectively.
If that is still too much resistance then two MOSFETs connected in series source-to-source can be used as a bilateral switch (S2), without extra diodes, at the expense of the gate driving circuits becoming more complex.
IGBTs don't offer much improvement because their reverse blocking voltage is very low (e.g.  20V) and their forward voltage drop (VF) resembles a diode.  Also, IGBTs switch ~10x slower than MOSFETs, despite their V*I product being much higher.
My suggestion on this case would be to grab nanopulser from your previous Dally circuit and try to short transformer secondary with pulsed 1kV over diode with it. Then see if that has same effect on transformer.
Itsu's nanopulser is a current source.  It does not function as a switch, thus it not capable of "shorting" the secondary winding of T1.
The nanopulser can affect T1, but this influence cannot be called "shorting" anymore.
MenofFather
Quote from: Hoppy on June 01, 2013, 04:27:32 AM
no.
