0 Members and 339 Guests are viewing this topic.
NickZ
    Itsu:
   Ok, I'll wind up the new yoke, connect it up and see if the output signals are more uniform, and I'll check the ringing as well.
  Since the two possibly still good fets have already been used, I'll use them again for this test, to see what happens.
I do have a 24v car bulb somewhere I think, if I didn't burn it up already.
  The new fets, and scope are not available, yet, until next week.  So, I'll do what I can until then.
   AG: Geo has not reported in for quite a while now. I don't know if he has been communicating with T-1000, or not.
        My inductor coil/3t coil circuit has had a very low output, and won't hardly even light a bulb, so I'll take a scope shot of that circuit's output when I get things better set up with the new yoke, new fets, and the Siglent scope.
itsu
Ag,
i had put up a screenshot of my 3 turn yoke coil output earlier in this thread, but it does not look pretty, see here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg463422/#msg463422
Yellow is voltage across the 3 turn coil, green is the current through it and as we where at resonance, they kind of are in phase.
I don't think it was open circuit as that could have destroyed my MOSFETs, so normally i use only loaded conditions.
Itsu
NickZ
  Yet, we see on the Ruslan and others videos, that they turn on the device first (without the load), and afterward they turn on the load. Although that may not be the most recommended way of doing things, they must be doing it for a reason. I think it's because the full load won't light without first filling up the caps, and then it will light with the full load on. Otherwise they turn on one or two smaller bulbs, then the bigger bulbs. Otherwise it probably won't start with the full 1000-2000w load.
NickZ
   Concerning the signal to the Kacher's base, I think that apecore is using the small torroid CT (current transformer) idea and taking the pulse from the inductor coil, throught the CT to the Kacher's circuit, and to Kacher's base. His Kacher is also frequency controlable. Maybe he can expound on how that has worked out for him.
   A current video of apecore's device working as he now has it would be good to see. When possible. As it sounds like it's working well. But, how well will it work when connect up to the feed-back path? Is my next question.
Hoppy
Quote from: NickZ on August 04, 2017, 10:16:23 AM
Nick,
You could also use 2 x 12V/50W auto bulbs in series.
