0 Members and 336 Guests are viewing this topic.
Void
Hi Hoppy. My own thinking as I mentioned as a possible key ingrediant is what takes it outside of
a closed loop system. I really don't know about the sparkgap, but it certainly
has the potential to be something that provides a 'doorway' outside of a closed system.
Corona discharge involves ionization, which possibly opens the system up to the surrounding environment
/ surrounding space.  My own thinking based on other things I have seen
is the earth ground is probably very important/critical, but the sparkgap may or may not be important.
The problem is Kapandze began to add other stuff in his later circuits likely to throw people off, and people like
Ruslan might have said stuff that just further clouded the issue and threw people further off track. :)
Going back to the basics with Kapanadze, a circuit setup by Frank Wyatt Prentice in his patent application
from 1923 uses just a high voltage generator/transformer, some wire, a few tuning caps, sparkgaps,
and earth ground as part of the circuit loop. Prentice reported that his circuit setup was producing overunity.
They way he uses the earth ground takes it outside of a closed loop. I think you have posted this schematic already in
this thread yourself some time back. My own experiments with earth grounds have shown some potentially
interesting results. I find working with sparkgaps however is a very messy business, as digital equipment
tends to go hay wire, and equipment can easily get blown. I think sparkgaps may possibly not be essential,
as I have seen some interesting results without using them. What Prentice showed in his patent
was seemingly similar to Kapanadze's early setups. Kapanadze may possibly have just done it in a
more compact way. It seems at least possible to me that they both were employing the same sort of effect. :)
P.S. Prentice was running his setup at around 500 kHz.
Void
P.S. I think it was Daly who first used the diode pulser circuit instead of a sparkgap,
and Kapanadze seems to have (possibly) figured out how to get the effect with a
single earth ground. So that would seem to indicate that the effect can be achieved with
a single earth ground as well. :)
Hoppy
Yes Void, I do recall posting something similar to the Frank Wyattt Prentice schematic. Its interesting that there was talk of Kapanadze utilising a remotely sited AC generator during his box device in garden demonstrations. This would possibly tie-in with the mains powered TX in figure 1 of the patent. Also, you may recall the odd looking 'washing line' between the road and disapearing into the tree in the green box video. Could this have been the transmitting antenna?? The box device would again tie-in with figure 2 of the patent, with the single earth and grenade coil acting as a rather unusual receiving antenna. If this were the case, then the difficulty in understanding the operation of the box device in isolation is understandable. However, I'm not sure that this setup can be considered as "so simple you'll laugh" but Kapanadze would have had access to this patent.
Void
Hi Hoppy. Yes, what you mention is possible I suppose.
My thinking was that it is possibly just an HF generator circuit, going to
a coil configuration, and a receiver coil of some sort, possibly tuned, and possibly the sparkgap
is used to generate high voltage pulses which maybe somehow draws in the excess current from the earth ground.
There are probably various simple experiments a person could do to test the general approach
using the Prentice patent drawing as a guideline for ideas. I thought I would just throw this out there
in case anyone was tired of banging their head against the wall with the Akula type circuit. :)
Akula may have used the tesla coil to provide the HV pulsing instead of using a sparkgap.
Daly used his diode based 'nano pulser' circuit.
Also, Prentice's circuit was apparently very sensitive to tuning. He mentioned having to tune
for resonance on the long wire he used extended over the ground, if I recall correctly now. It is
interesting that this was apparently a resonant system that included the earth ground segment as part
of the resonant circuit. (hint, hint).  ;D
AlienGrey
Quote from: Void on August 06, 2017, 05:10:34 PM
Just been reading some of these ideas or flights of fantasy ;) so how would the HF you refer to connect to this device and how would it become resonant with the earth and more to the point where would the gain come from and what would be the common denominator be here? As far as I can see we are not talking about one thing but more like several conditions have to be met here as every section does a function and it might be an idea to study some of the Russian explanation before one wastes huge amounts of time and money on a development system hardly any on in the western world has got to work so far. However, if your Russian vocabulary is excellent and you don't get scammed be my guest jump in feet first and good luck. Allen
