0 Members and 337 Guests are viewing this topic.
T-1000
Hi all,
Catching up with posts you guys made. There are few things I would like to point out.
In regards to yoke/toroid. The primary coils setup worked best for me when there are bifilar winding with center tap. Which means 2 paralel wires 12-24T on primary on side-by-side with starting and ending on same places. The ending was conected together and connnected to the positive rail and the begining of coils connected to MOSFETs. It is Sergey Alexeew way and apparently worked best wih BEMF because it was made positive not negative(which overheat internal diodes of mosfets)
In regards to effect needed to achieve. I might repeat Nth time but there is no magic. Ionization of air with nanosecond pulser/Tesla coil then abruptly shorting HV over spark gap/etc create ambient response which is extra energy flowing for some time by inertia. That was a way akula explained to me.  So you get charged Air/Ground capacitor after primary circuit is already switched off. That energy needs to be collected and converted... The one of simplest circuits was shared from akula with 2 spark gaps. Which was designed to do exactly that mode of operation.
In regards to Geo, - seems he is unreachable for a month or so, not sure what happened. If you are close to Aruba, might ping him...
Cheers!
Void
Hi Hoppy. Yeah, I thought I would just mention the Prentice patent since he was an
actual working engineer, and said he found the earth ground OU effect (if that is what is was)
by accident when working on a project for the railway. Maybe there are some details in his setup
that could help people, as he seems to have been pretty specific about his setup details in
his patent application notes. However, I know people have been experimenting with this stuff for years
already, so if the OU effect is real, it sure seems it is not easy at all to find the effect.  Maybe the Prentice
patent is just one more piece to the puzzle. :)
Void
Quote from: T-1000 on August 07, 2017, 09:38:48 AM
Hi T-1000. Thanks for the info. Strangely though Akula seems to have had
no sparkgap or pulser circuit at all in his 'first self runner', and no sparkgap in his 'second
self runner' as well, as near as I could tell anyway.
AlienGrey
Quote from: Void on August 07, 2017, 09:42:49 AM
yes back in the old railroad days of the cow boys (nothing has changed much) the telegraph wire ran along the rail track and a leg was used to earth, the relays would do a ghostly chatter i high solar activity. if a coil could harness that activity what are you waiting for ? so whats its frequency of maximum amplitude? if the earth Schuman resonance is really low hz we need a bloody long length of wire miles in fact but wait some clever Russian invented the Grenade coil, hmm! So what does that do when its wound correctly? find out how that works!
AlienGrey
Hi all,
Cheers!
Hi Arunus nice to see you back, where have you been?
In regards to yoke/toroid. The primary coils setup worked best for me when there are bifilar winding with a center tap. Which means 2 parallel wires 12-24T on primary on side-by-side with starting and ending on same places. The ending was connected together and connected to the positive rail and the beginning of coils connected to MOSFETs. It is Sergey Alexeew way and apparently worked best wih BEMF because it was made positive not negative(which overheat internal diodes of MOSFETs)
Yes, i experimented with this it was brilliant and also produced other duplication of frequency harmonics easily, however, I don't understand why you are using so many turns and so high a voltage I had excellent results using a good quality toroid and 8+8 t and only 12v. did you have to double the 4 turn wind to 8 turns and the 28t to 58 turns to get any thing to work as i suspect it would cause a huge damping down and suppress any self-resonance oscillations  ?
Regarding the Akula circuit, I have yet to play with that one but found adding a diode capacitor circuit produced a high static pull down of charged particles which charged anything in the lab with a good spark each time touched which would be of use in this device. Allen
