0 Members and 348 Guests are viewing this topic.
NickZ
   AG:  My yoke is fine.
   Thanks, but how about you showing us how YOU obtain great results.
   Buy that yoke yourself and show us how well it works for you.
   Instead of telling someone to throw their yokes away and buy another, because you think so, without trying it out yourself,
first.
   My yokes can light up 700w worth of bulbs, on the Mazilli circuit. Without using any limiting voltage regulator circuit.
So, there nothing wrong with the yoke(s).
   However, there may be a current restriction due to the voltage regulators circuits.
   In any case I'm working on tuning the ringing with a 24v, 18w car bulb on the yoke's input at the center tap for now.  And not full power, while testing out the snubbers caps.
Hoppy
Quote from: Void on August 09, 2017, 10:43:38 AM
Hi Hoppy. I couldn't follow what Kapanadze did in that video where he plugged
a plug into an AC socket on the workbench for a moment and there was a loud
buzzing sound heard. By infinite COP, I guess you mean that the power stayed on
for a little bit after they flipped a switch? There was definitely something unusual going
on with the power switch on the tobacco can, where they seemed to have to flip it a few
times before power to the load would go on or off. Is that what you mean?
Hi Void,
Yes, just before the buzzing is heard, he disconnects the battery. He then inserts the mains plug and gets the buzzing, flips the switch on the can, then pulls out the mains plug, leaving the lamps shining brightly with no apparent power supply. Before he inserts the mains plug, his assistant throws a switch on the blue inverter. There was a  suggestion made on the fora that this switch connected a second mains suppply sitting in the inverter, through a specially wired output connector into the can.
AlienGrey
Quote from: NickZ on August 09, 2017, 10:58:31 AM
first.
I already have I sent Arunus a clip pic of the wave form he won't talk to me about it ;) look a few pages back you will find it. i think i showed how to wind it.
AlienGrey
Quote from: AlienGrey on June 19, 2017, 06:51:17 AM
TL494 driver device. Notice 3 control pots PW Dead Time (2nd  PW over ride of PW) later removed as error amp shuts down device.
Also observe oscillograph of what looks like unstable driver stage. Went through all circuitry and re wound yoke found unstable wave to be ferrro related. Spoke to T1000 and note in later rewind yoke problem removed.
Notice 3rd pot removed (dead zone wiper connected to 0volts
Here I have one or two cores some are better than others but all perform with an earth !
NickZ
   Maybe you can show us a video of your device powering some bulbs, instead. And just what it can actually do.
As well as some scope shots of the output signal, at the inductor capacitor, etz...
