0 Members and 284 Guests are viewing this topic.
MenofFather
Quote from: NickZ on June 02, 2013, 02:09:38 PM
  @menofFather:
     Look at this video, from Tiger (possibly).  Is this showing a self runner?  Looks like a simple feed-back path back from the center tapped coil back to the primary coil circuit.  The main thing is it self running, or not.
It shows a circuit very similar (primary coils) to my version of the Lasersaber 2.0 Joule Ringer circuit that I'm currently using, but with some filter caps, a resistors or two, but other than that it is very similar to my set up. Although wired totally different, with center tap from the output coil going to ground.
There is a clear diagram, and sharper focused video for a change.
  http://www.youtube.com/watch?NR=1&v=HJ0yrCKafaQ&feature=endscreen
  If Gansha is corrent then Akula was replicating some of Tiger's work, but I think that there is a
lot more that we don't know, yet, nor are either one of them telling us.
  I have gotten NO reply to my e-mail from Akula,  which also makes me think...that this is a serious no joke device, and from which there will not be any further information (freely) given. As it may also really have been sold, as was mentioned.
This video is Tiger and there is very small power. It selfrunner, but can run from radio waves, but not from self. And in schematic is mistake. In general windings must be parallel to it capasitor.
T-1000
Quote from: dllabarre on June 02, 2013, 03:36:02 PM
T-1000
In this schematic.
Based on L2 wire length the calculated resonate freq of L2 is 24.1mHz.  You confirmed this a few days ago with me.
What freq should the L2C2L3 tank circuit be?  24.1mHz?
I have L2 & L3 inductance values.
I'm trying to determine what value C2 should be.
If I know the inductance and freq I can calculate the size (Farads) of C2 using an online LCR calculator.
Thanks for your help
DonL
C2L3 is 1/4 of L2 resonant frequency and this frequency is resonant for L1C1. Also sorry a bit for confusion, with the 20mHz+ natural frequency is meant for Tesla coil with open end to resonate as virtual antenna with Earth ionosphere and in circuit I posted it is not that case.
The L2 is voltage source same as in shorting coils with opposite polarity and C2 L3 is resonant current source same as in induction cooker.
P.S> This concept is only general idea following directly what Romanov did in latest explanations on youtube and there is way of trial and error to find correct values.
NickZ
  I realize that the diagram from Tiger is not exactly the same as the device, as the diagram is showing two transistors, and not just one. But where is the mistake?  Does Tiger say that it is running on radio waves, and how much voltage/current is "little power"?
    IF,  it is a self runner (as you can hear it when it kicks on) that is a very important point, even if the output is small.
   You are saying, "Windings must be parallel to it capacitor"?  How should the windings be parallel to the capacitor?
  If feel that these are all important steps taken by Tiger, that have possibly led to where Akula has further taken that technology. And the working ideas were simpler at that point, and easier to understand.
  Here in the TK green box video (below) the ideas were also simple, and the two transistors, were also getting hot, back then, also.
   I see several similarities with what Tiger was doing in his versions of the TK devices.
  Here is a partially translated version of the TK green box back-yard video.  I'm still learning some new things from it.
            http://www.youtube.com/watch?v=OIWi1mELJvY
  TK is saying that it may be possible for even more than 5kw to be drawn from that device.
Wow, that would be awesome, if possible.   That's all I need...
  The charging or feed-back path was done with a large iron-core transformer, going from a coil on the air core transformer to a full bridge rectifier and back to the 12v battery, to recharge it.
  TK says that the input source is not coming from stray electricity, or radio waves, etz... he argues that point, but that it's the same available AMBIENT source as what Tesla talked about.
dllabarre
Quote from: T-1000 on June 02, 2013, 06:30:41 PM
If I understand this then:
C2L3 Freq is calculated to equal a 1/4 of L2 resonate freq
and L1C1 freq = C2L3 freq?
So L2 Resonate freq = 24mHz
and a 1/4 of that is 6mHz.
So C2L3 freq needs to be at 6mHz
and L1C1 freq also needs to be at 6mHz???
DonL
itsu
Using a 220V-12V transformer driven by a variac from mains, i was powering a 12V/21W bulb via the MOSFET shortener
I used the single diode in the drain, so not the FWBR.
One probe was across the bulb showing the voltage and the other one was across a 0.1 Ohm resistor in the bulb return lead measuring the current.
We see some increase in light intensity when shortend, but also the input on the variac increases from 22W till 30W.
Video here: http://www.youtube.com/watch?v=CpWrPrwPcWo&feature=youtu.be
Regards Itsu
