0 Members and 368 Guests are viewing this topic.
ramset
Hhmm
well I heard today that a member and builder here was put on Moderation [AG],normally these things are not spoken about.
but this  ??
this is a poor option IMO , I have not been able to read much here do to a horrible eye injury, nor do I criticize our host
he has much going on in his life ATM.
surely we have other options here?
removing Ag's membership should not be on the table [seems it is]
we need all the help we can get around here ,good builders with skills don't grow on tree's
we are after all men with the same goals ,and the same open source beliefs .
just one mans opinion
respectfully
Chet K
Thanks Grandma
Void
Quote from: Bat1Robin2 on August 18, 2017, 09:02:27 PM
Only 2 energy fields in the universe Electric and Magnetic.  Coils store magnetic , Capacitors store electric. When these 2 fields combined in an oscillation they can radiate in electromagnetic photons. Electric is based on surface area, pressure, stored at the electron layer and stationary. Magnetic field is based on mass, dynamic, stored at the atom nucleus, this is why magnetic energy storage can be increased with large iron cores. If this device brings in a large electric field from the tesla/katcher circuit and a large magnetic field from the yoke circuit will it be multiplied, no it will be added.  Even tho power is voltage time current, there is an error in thinking it will multiply in this manor. Power is voltage times current in the same component at the same instant. Not voltage from one source times current from another source. The shape and arrangement of the coils and driving wave forms are irrelevant. Resonant circuits are only circuits capable of storing equal amount of Electric vs Magnetic energies to oscillate back and forth, efficient yes over unity no. It seems the only significant source of energy we could tap is from the matter itself. We need a catalysis to coax out the energy from matter. see www.brilliantlightpower.com So what is the catalysis in this device? At the web sight shown they use hydrogen and the matter to extract from and K potassium as the catalysis. So perhaps we need to coat the wires with a potassium coating and hermetically seal this device in hydrogen to make it work.  ( or hide a battery in a box)
Interesting comments. Adding of the power from the two sources versus multiplication is what I see as well,
regardless of the coil configuration. Somewhere in there a secret is still hiding. :)
Grumage
Quote from: NickZ on August 19, 2017, 04:44:27 PM
   OK, I'll do that later tonight.
   But, should I use the 12v battery instead of the PSU? As I'd be running new FETs at possibly close to 300v.
   I've tried to do what I can to figure out why there is a difference in the running frequency, but I still don't have a clue. The wires lenght are the same for both fets. And the TL494 and drivers run very similar, so it's probably not that.
Dear Nick.
Do try the battery, in one of my experiments I was seeing a linear ring signal, turned out to be interference from the quite expensive switch mode bench power supply I was using.
Might even shed light on your odd FET voltages?
Cheers Graham.
Grumage
Good morning Chet.
I couldn't agree more with your post.
With Stefan being so busy these days it's highly unlikely that any of AlienGrey's future posts will be seen, as Stefan is the only moderator.
We all have our opinions and life dictates that some will clash with others, let's keep it clean and start afresh?
Cheers Graham
NickZ
   Grum:
   I'm using a 12v, 7ah battery at the moment with one foot long connection wires. And still seeing the big spikes, and different ringing frequencies.
  I will remove the snubber caps to test the ringing frequency with them off. But it only take a few seconds to see the fets go up in smoke. Actually they don't even get a chance to heat up, before they blow. And is why I'm concerned about removing the caps to test the ringing frequency.
   I'll know more later today. As I'm letting the device run for a while to drain some juice from the battery, down to 10.5 volts.
Then I'll remove the snubber caps and retest.
   Looks like Void got his way, with Alien Grey.
