0 Members and 360 Guests are viewing this topic.
itsu
Nick,
OK, so you have fat 3W resistors, double check (google) they are no wire wound types.
i don't know if 15nF would be better then 20nF, you have to look for that yourself.
I don't think it will matter that much.
I don't understand your remark about the 5000V going through the MOSFETs with the Kacher on.
It should not as they are separate circuits.
Itsu
NickZ
   I checked I but could not really identify those types of resistors properly. In any case, those are the only resistors that I have here on hand that are close to the right value, and may work, so we'll see. If they don't work, I'll order some new 47 ohm resistors, as those are the closest to recommended 45 ohm.
   Don't worry about my comment about the Kacher's voltage interaction on the induction circuits. Just some concerns of mine...
   They may be separate circuits, until you turn both on together. Then they become one even more complex thing.
Hoppy
Nick,
If the resistors are the same as the existing large resistors on your circuit board, then they appear to be wire-wound. If your gate resistors are of this type, then also change these for small carbon or metal oxide type resistors.
Void
Quote from: NickZ on August 24, 2017, 02:23:14 PM
   I'm also thinking about the 5000v (or whatever voltage) that the fets are going to be getting running through them when the Kacher is turned on.
The series resonant loop including the yoke output winding, the series capacitor, and the 'inductor' winding
on the grenade probably act to help isolate the FETs in the push pull driver circuit from high voltage
induced from the tesla coil on the grenade winding.
NickZ
   No, Void. It's just the opposite. A video that I made previously was showing how the Kacher's HV pulses are going through to every thing, including even going back to the input source.
   The earth ground connection is the only thing that helps with that.
