0 Members and 291 Guests are viewing this topic.
AlienGrey
Hi I'm sure many will help you out with that question on this page and you can find many circuits in the data base on a good few designs, but this device would need access to a good earth out side with a metallic rod sunk in some damp portion of the garden, common internal electrical earth's don't work too good with household earth nor  plastic gas or water pipes or apartment buildings ect. unless you know you have access to an independent earth i wouldn't bother, but some other ideas might not need an earth.
Hope that bit helps.
Utopia Now
Thanks AlienGrey,
2 months ago  I driven a 1 meter sixty centimeters rod in the ground where I live  ( it is under my house  where it is always damp ... the water level is pretty  high  where  i live.
And i soldered a copper cable onto the rod, about 12 meters long.
This video from Itsu  that looks very  nice and tidy  ... is  this  according to  a schematic from Aleew Sergey ?  or is  it modified , changed .
https://www.youtube.com/watch?v=uBCAmXzmgkg
What schematic are you  using Itsu.
I attached a screen shot  from a Alexeew Sergey video   https://www.youtube.com/watch?v=gFQvMjj6DD4
itsu
Quote from: Void on August 29, 2017, 06:38:29 PM
Hi Itsu. That was a good video. Was there any particular phase shift setting for firing the kacher
that made the load light bulb at all noticeably more brighter than other phase settings? For example, did you get
any better brightness on the bulbs when firing the kacher on the current peaks for the resonant loop?
Did you have an earth ground wire connected, and, if so, where was it connected to? I realize the video was from
Nov. 2015, so you may not remember all the details now.
Hi Void,
no, shifting the kacher firing moment did not show any effect on the brightness of the bulb.
I could both shift it ±90° as well i could flip it over to fire (and shift) to the negative side of the sine wave.
I had an earth ground connected, but that is one of the reasons i stopped working on this setup as that ground probably was not good.
It consisted of about 10m heavy breaded (1.5cm wide) copper wire connected to the copper plumbing system here on my attic where i have my bench.
This copper plumbing system is at the ground level connected to the main earthing point of the house.
Its OK for normal household uses, but i doubt its what is needed for this setup.
Itsu
AlienGrey
Hi I thought I would mention the Earth thing which to my mind reflects all the way through this device is the ground frequency, if your using 38m of wire on your grenade and 1/2 that on your inductor you need to introduce the missing another half back into the tuned circuit, this is why you need such a long Earth wire to complete the wave.
Adrian Guska mentions this in his video.
regards Allen
itsu
Utopia Now,
In my linked video above (non PLL 1) i was basically following the Oleg diagram, see link here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg463785/topicseen/#msg463785
It has a PLL chip (4046) to generate the push pull signals, but later i found out that this was not really a phase locked loop system.
So i was using a TL494 setup, but kept the rest of that diagram (therefor the name of the video "non PLL 1")
More later i switched to the lossless clamp design from verpies as a yoke system.
So its not that easy to simply give a diagram, as everybody will use their own.
I am afraid you need to start reading up on all the posts to get a good idea of what was tried.
A 1.6m copper rod will hardly do for a good ground, something like 10 to 15 meters would be more useable, please read up on earthing systems here in the Netherlands.
The linked video of my TL494 system was for Nick, who had build the Stalker TL494 circuit i think, so a copied it on a breadboard.
The push pull circuit behind it was something i was using for something else, but was useable for this demo.
You have to go back in this thread to find the discussion about this used tl494 circuit, its around page 1160.
Regards Itsu
