0 Members and 94 Guests are viewing this topic.
forest
I think at the end it does not matter if there is higher current or higher voltage. Both should be possible, just having own limitations. For example for higher voltage it's hard to switch current precisely, but you don't need a solid core.
MenofFather
Quote from: NickZ on June 02, 2013, 06:40:01 PM
  I realize that the diagram from Tiger is not exactly the same as the device, as the diagram is showing two transistors, and not just one. But where is the mistake?  Does Tiger say that it is running on radio waves, and how much voltage/current is "little power"?
    IF,  it is a self runner (as you can hear it when it kicks on) that is a very important point, even if the output is small.
   You are saying, "Windings must be parallel to it capacitor"?  How should the windings be parallel to the capacitor?
  If feel that these are all important steps taken by Tiger, that have possibly led to where Akula has further taken that technology. And the working ideas were simpler at that point, and easier to understand.
  Here in the TK green box video (below) the ideas were also simple, and the two transistors, were also getting hot, back then, also.
   I see several similarities with what Tiger was doing in his versions of the TK devices.
  Here is a partially translated version of the TK green box back-yard video.  I'm still learning some new things from it.
            http://www.youtube.com/watch?v=OIWi1mELJvY
  TK is saying that it may be possible for even more than 5kw to be drawn from that device.
Wow, that would be awesome, if possible.   That's all I need...
  The charging or feed-back path was done with a large iron-core transformer, going from a coil on the air core transformer to a full bridge rectifier and back to the 12v battery, to recharge it.
  TK says that the input source is not coming from stray electricity, or radio waves, etz... he argues that point, but that it's the same available AMBIENT source as what Tesla talked about.
http://realstrannik.ru/forum/19-svobodnaya-energiya/15018-opyty-tiger2007.html?limitstart=0#14723
" Does Tiger say that it is running on radio waves, and how much voltage/current is "little power"?"
Tiger asuming, that it can run from waves of other divices. What current I dont know. But it try light led and with not succesfully, how I understand.
MenofFather
Кстати , когда менял конденсаторы на более качественные , такой же емкости , система затухала . <...> Питание было 12 в , после запуска проседало до 5 в ,затем поднималось до 7 - 8 в и на этом стабилизировалось . В течении суток это напряжение плавало , что косвенно указывает на улавливание энергии полей (наводок )всяческих бытовых приборов . Жалко , что концентрация этих энергий мала .... - Tiger
http://realstrannik.ru/forum/48-temy-freeenergylt-antanasa/129332-ustanovka-akuly-povtorenie.html?start=126#133996
MenofFather
Red wire on yoke may going to drosel like in this video. http://www.youtube.com/watch?feature=player_embedded&v=5w9nJahkFB0 In this video going to primary winding of air core transformer, but in final free energy divice secondary winding of air transformer to nothing conected.
NickZ
  @ MenofFather:
     Thank you for the link to the Russian Forum, there are two very interesting videos to be seen there from Phoenix:
  I'm glad to see that I'm not the only nut case blindly following this replication, in the whole world.
  Here is yet another video by Akula:
http://www.youtube.com/watch?v=gTDB3NVxOP0&NR=1&feature=endscreen
  It is very important to see all the steps that were taken to arrive at the final Akula self-runner.
As I mentioned before, that Akula did not use a battery/inverter/rectifier, or the feed back path,  in his first tests. That is what we need to do, also.  In order to see how the induction heater approach can be implemented into these amazing circuits.
  I am still stuck at the 1st base, which is, not being able to get any useable output from the 3 turn coil.
But, I'm still trying hard to be able get all this.
   Menof:  Thanks again for all your help and attention.
        Nick_Z
