0 Members and 280 Guests are viewing this topic.
NickZ
   Void:
   It's not just a "little effect". It's the real deal... without it there is very poor output.
   I did install a CT like you mentioned, today. And did adjust for the highest output at the CT, as shown on my scope.
   But, what really seams to set it off, after tuning with the CT,  was moving the yoke around a bit. That kicked it into what Itsu would call the "Kaotic mode". It's there that the magic lies, and the effect is to be seen. Similar to what the Mazilli would do.
    Itsu: It seams that the static ringing noise like Geo had shown, is part of the "spacial resonant effect". At least on some devices, like mine and Geos.
And without that sound I don't see the same kind of "effect". That sound can also be tuned best when it reaches a steady clear ringing sound. I'll show all these things in my next video. If my fets live that long without the proper snubbers on. Which is why I'm lowering the load of bulbs on, until I reinstall the right type and value of carbon resistors back onto the snubbers. As the higher load, like 600w, induces higher peaks, up to 230v in my case.
Void
Hi Nick. Ok, that is really interesting. It sounds to me like the PWM
becomes quite unstable when that happens, but I guess the big question is
why. Will be interested to see your video.
AlienGrey
Quote from: NickZ on August 31, 2017, 09:49:10 PM
   Void:
   But, what really seems to set it off, after tuning with the CT,  was moving the yoke around a bit. That kicked it into what Itsu would call the "Chaotic mode". It's there that the magic lies, and the effect is to be seen. Similar to what the Mazilli would do.
    Itsu: It seems that the static ringing noise like Geo had shown, is part of the "special resonant effect". At least on some devices, like mine and Geos.
And without that sound, I don't see the same kind of "effect". That sound can also be tuned best when it reaches a steady clear ringing sound. I'll show all these things in my next video. If my FET's live that long without the proper snubbers on. Which is why I'm lowering a load of bulbs on until I reinstall the right type and value of carbon resistors back onto the snubbers. As the higher load, like 600w, induces higher peaks, up to 230v in my case.
Hi Nick!
I must admit it does sound a little too good to be true, and I must admit I am beginning to a appreciate your past scepticism on my part, but yes you have got there and I must offer you congratulations on your achievement!
Allen
Hoppy
Good climb Nick. The peak is in view!
Can you show a scope shot of both mosfet source / drain waveforms? Don't use your new scope for this! I got to this chaotic stage and reckoned that HV was affecting the PWM. As you say, I think this is the 'effect' that Geo and others have demonstrated and may well be the real deal to achieving what others claim to be a self-running device. You will need to monitor input current and voltage whilst this effect is taking place. I saw increased current and like you, one very hot mosfet.
itsu
Quote from: AlienGrey on August 31, 2017, 08:10:18 PM
Itsu I was going over some of your information you shared on this post I recall you saying you failed to achieve to gain Akulas goal, If I remember correctly somewhere in that or a similar video he mentions a threshold where he says the focus lies, I'm pretty sure the frequencies you quote are far too high and you may do better to look lower.
Regards Allen
Allen,
its hardly possible to go lower on the kacher, the 888Khz which should be 1/3th of the grenade limits this, especially with the dimensions it needs to be contructed with.
Itsu
