0 Members and 332 Guests are viewing this topic.
itsu
Quote from: NickZ on August 31, 2017, 08:56:45 PM
   So, looking lower, I hit on it... Radio Moscow. Suddenly the device starts to sound just like Geos does.
The silence was gone... and the bulbs get brighter, big time.
   It's not that easy to find, that sweet spot, as I had searched for it throughout all of the full ranges of what the TL494 controllers can do.
   So,  I placed just a smaller 50w bulb on as the load, and started seeing a tad of increase in bulb brightness with the Kacher on. Light at the end of the tunnel, you might say. Then all of a sudden, while moving the yoke, just like Geo showed, there it was, doing the Geofusion ringing thing.  After it's been silent up to that time. There it is was... I had found the sweet spot.
   So, I went to take my dogs for a walk, and when I get back, I can't find the sweet spot again,  no matter how I adjust the controllers. Oh,  where did it go?... Where is that silly wabbit.   But, I did find it again,  and again.
However,  one of my fets gets real hot if I stay there too long. There's always a "but",  but so what...
   Radio Moscow at last...
   PS:  You'll know it when you hit on it. It starts ringing in Russian. Oh, don't forget the vodka, and cigs.  Or you'll never see it.
Nick,
i understand your excitement, but without proper snubbers, you probably hit like Void and Hoppy mentioned some oscillations / feedback (chaotic mode).
It will unbalans the yoke- and TL494 system and cause all kind of effects   ( i had my near by temperature controlled Weller soldering system shoot up to 500°C).
But be welcome to further explore this, and a video would be very nice to see.
Itsu
itsu
Quote from: Void on August 31, 2017, 09:24:26 PM
Hi Itsu. If you still have your PWM connected to the ferrite yoke (or equivalent toroid)
with the series resonant loop going to the grenade, and, if you have
some time at some point, I wonder if you could check something for me?
Would you be able to wind a few turns on a ferrite toroid to make a
homemade current transformer and place it over the wire on the series
resonant loop (like Ruslan did previously), and connect one scope probe
to the homemade current transformer output and a second scope probe to show
the output voltage across the two output wires on the grenade coil with
the PWM running? A commercial current probe may include phase shift correction,
so I wanted to see if possible how it works for you when using a simple homemade
current transformer as Ruslan did previously, for comparison.
I just wanted to compare the phase difference that you are seeing between
these two waveforms to what I saw in my own tests. In my own tests using a
homemade current transformer like that, I did not see the 90 degree phase
difference between the two waveforms (loop current and grenade output voltage)
which Ruslan showed in one of his old videos. Just wondering what you get
when you use a homemade current transformer on the current loop? I see
either 0 degrees or 180 degrees phase difference (depending which way the scope probe
wires are connected), not the 90 degree phase difference that Ruslan showed (with
the Kacher turned off).
Nick: That funny noise you mention may just be a spot where the
PWM goes unstable (parasitic oscillations or similar). That might well explain why
the FET gets hot. You would likely be able to see what is happening by looking at the
Drain to Source waveform of each of your PWM driver FETs with your scope
when it is happening. Would be informative to see what the scope shows
on the PWM driver FET waveforms when that is happening. It is interesting that you
see a little effect from the tesla coil when the PWM is doing that however.
Void,
i would be happy to conduct those tests, but we have been there before a few times and these tests were already done.
See f.i. this link in which there are again 2 links with the 2e one showing the measurements you ask:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg497451/#msg497451
I will setup things later today/this weekend.
Itsu
AlienGrey
Oh yes this is really fun ;), I can see this next little 'gem/' is really going to be popular, now that Nick has found his sweet spot (I'm sorry but this is because the meal has been cooked with out the correct and or all the ingredients, because we have all not been able to understand what was said) a note needs to be taken of that frequency and the Katcher and grenade and inductor either need rewinding to be in resonance for maximum effect or in some way will need retuning.
Hence why the device is not transferable around the planet every one would be different.
All this in the Vids and some of the Russian forums.
Regards Allen
AlienGrey
Void
Quote from: itsu on September 01, 2017, 04:51:46 AM
Void,
Itsu
Hi Itsu. That's ok. No need to set that up if you have already done that.
I was curious about the 90 degree phase difference between the loop current and grenade
output voltage waveform which Ruslan showed, but it sounds like you came to the conclusion
from your previous test that Ruslan was seeing the 90 degree phase difference because
his CT was saturated. Thanks for the info on that.
All the best...
