0 Members and 330 Guests are viewing this topic.
Hoppy
Quote from: NickZ on September 01, 2017, 12:14:21 PM
   The reason that the one fet gets hotter, is because that's the one that is showing a higher peak. And when the effect kicks in, the voltage goes over 250 volts. Therefore that the one fet get hotter than the other one. And the other one stays much cooler. And yes, there is higher draw from the PS.
Nick,
The mosfet is running into avalanche which is why you need to clamp the voltage, otherwise you will be unable to run without the risk of smoke. You may find as I did that you can disconnect the 'cold' mosfet and still get the effect.
NickZ
    Hoppy:
    Don't worry, WE are going to get to the bottom of this. But, this "effect" does happen without the Kacher.
   Yes, but both fets are working and the gate signals seam ok. Even though, the system is not fully tuned yet. As I just found the place where the effect happens. No doubt that I'll need to keep the peaks down to safer levels. And is why I've been using much lower wattage bulbs. As mentioned the voltage peaks go up if more bulbs are added, as well as when it hits that Spacial, as well as special point of resonance. Most may never see it. As I never have before.
   There probably will be other sweet spots that don't heat the fets up as much, as Geo also found.  I'm just not there yet.
   Watch Geo's last video, about 6 months ago. I believe he's hit on the self runner, working now, since that video was made.
He has a new trick controlable Kacher system that he has not shown working on any video, as yet, as far as I've seen.
His Serv friends must have helped him build that one.  And it looks, kick ass.
   My hat's off to Geo...  I miss him being around... who knows, I may be the next to go, silent...
AlienGrey
From what I can see that 43kh is a bit too high, I wouldn't mind betting that's more like Ferro resonance from a yoke.
Nick is it humanly possible to put a clamp meter around your earth cable just to see if it;s drawing ground current?
Allen
Void
Hi Nick. If you mean GeoFusion's very last video where he is running the
grinder on the output of the grenade, if you read Geo's comments to other
people under his video, his kacher is turned off, and he also commented that his
kacher was not having any effect when he turned it on. Or were you referring to another video?
"Kacher was not operating at the moment,
it was only pushpull on the 3-4T series resonance doing the work"
"and this is only series resonance without kacher on.
infact, the kacher really doesn't have influence on it any more if I turn it on, ..."
"Geofusion some crazy test XD with success"
https://www.youtube.com/watch?v=H6sFHCwF_MU
Edit (update): Itsu pointed out that Geo is using rectifier diodes at the output of his grenade coil,
so the grinder was apparently running on DC.
Hoppy
Quote from: Void on September 01, 2017, 01:57:47 PM
It's interesting that the PWM would run the grinder at the frequencies it operates at
(10kHZ to 40 kHz). Geo seems to have been running his PWM at maybe 10kHZ or
15 kHZ, as he added some extra capacitors in the series resonant loop. It does show
that whatever kind of electric motor that they have in grinders can maybe run at the 10 kHz or
higher frequency range however, which is interesting, as that maybe adds more credence to other
videos where people are running power equipment like grinders from the output of these devices.
Hi Void,
Makes sense as the grinder has a low impedance, thus good matching to source. Note that the grinder although turning is way under powered. Duty cycle would be important here. Nick mentions that his spike level is lower when lower powered bulbs are used, which again makes sense in respect of impedance matching, as lower powered bulbs will have a higher cold and hot resistance than higher powered bulbs.
I'm pleased to see that Nick has achieved the 'effect' and has the perseverence to dig-in and move up to the next camp, which will hopefully reveal something not seen by those of us who are still resting.
