0 Members and 286 Guests are viewing this topic.
itsu
Hi David,    welcome.
No, to my knowledge, nobody was able to get this device (which one do you mean; the original Dally device, the Ruslan device, etc.) to work yet.
But Nick and others are still working on it.
Regards Itsu.
DavidWolff
Quote from: itsu on September 09, 2017, 03:46:39 PM
Hi David,    welcome.
Regards Itsu.
Hi I have been looking at some of T1000's statements  and modification  recommendations and i sort of get the idea the Katcher or Tesla coil should realy be considered as a high voltage collecting transmitter that attracts positive ions in the order or of Mhz possibly around the 2 mhz region by pulsing  in a semi free running mode.
T1000 also talks of a collecting 1/3 harmonic winding under the grenade coil, this would involve considerable spacing between each wind or the bulk size and heat would be considerable has any one built this winding using fishing line as spacing between turns and done any testing as yet or am I wondering off into oblivion ?
Kind regards Dave Wolff
itsu
Hmmm,  "a high voltage collecting transmitter that attracts" he  well, i hope T1000 can confirm your idea.
Itsu
NickZ
  David:
  The fishing line idea has been tried on the Kacher's secondary coil. But it does not need to be 2MHz, as 1Mhz to 1.7 or 1.8MHz is normally high enough. Mine is running at 1.1MHz.
  Itsu: I could not obtain the needed 43 or 47 ohm 2 or 3 watt carbon resistors for the snubbers. So, I'll try to order any resistors that are 47 ohm, and 1k ohm, and see how they do.
    I placed the same 56 ohm resistors for fet snubber that I had on before. And I've been testing some other resistors for the Oleg snubber, but they ALL get too hot. Even a big white ceramic 5w 2.2k resistor gets hot, it just take longer to get there. Also, these snubber do inhibit the "effect" in various degrees. So, I'm not sure what to do about it.
  I think that a flat top square wave may not be the best way to go on this. As it seams that some ringing there is still needed, but the extreme peaks do have to be dealt with.
   The second pic is from Stalker, and is what his best fet signals look like. His peaks go from 238v to 262 volts.
itsu
Nick,
there is something wrong with the data presented on that screenshot of yours.
It concerns both traces, and you should be able to figure out what is wrong by your self by now.
Well, if "these snubber do inhibit the "effect" in various degrees", then there is a problem as you need those snubbers for safe operation of your present components.
I can only help you with trying to get a clean square wave signal, but if thats not wanted as it kills the effect, then there is little i can do.
I can only suggest to use components (MOSFETs) which can handly these spikes, like IRFP460 MOSFETs and run them without snubbers like stalker seems to do.
Regards itsu
