0 Members and 469 Guests are viewing this topic.
AlienGrey
If any ones interested on faffing about with the off or dead time (same thing) and wants it longer you can use an RC delay line between the TL494 output and the FET input on your IR2110 chip, but you will have to set it up with a scope, but if you want 49-49 use a d type circuit, but both ideas are a waste of space in this project.
Also, I have a PCB design for Akulas katcher controller if any one wants a copy I can skype it to them or whatever method you like.
Ran out of bits but you can see whats what on the pcb layout
Hoppy
Quote from: T-1000 on September 12, 2017, 07:24:52 AM
When you directly charge capacitor from the HV output it will be always similar to this case. But the case we are after is, - when the the capacitor is in near field (ref - Tesla Ambient Receiver patent - http://www.nuenergy.org/uploads/radiantenergy.gif ) and the charge of capacitor is from the ambient source and the the main power source is not used on that moment.
I may suggest try place scope leads near Tesla coil and to the cap with voltage divider between cap and ground. Then see if you get that effect happening at certain voltages and frequencies of the Tesla coil. Myself still in middle of that process so cannot tell definite results at the moment.
Cheers!
Please detail your setup for those wishing to experiment along these lines.
Hoppy
Quote from: NickZ on September 14, 2017, 11:27:27 AM
  Neither bigger heatsinks nor fans can keep up with the avalanche mode.
Agreed. That's not the purpose of heat-sinks.
Have you tried looping back for self-running whilst in the chaotic 'effect' mode?
T-1000
Quote from: Hoppy on September 16, 2017, 04:58:10 AM
As you wish :)
https://i.imgur.com/cSIRhgA.jpg
The Tesla output voltage should be 3-30kV, depending on which level you wil get pre-streamers condition where ionization is about to happen.
Hoppy
