0 Members and 385 Guests are viewing this topic.
AlienGrey
Oh yeah! Streamers nothing but a streama always got his hands in in head oh no! lyrics from Roger Hodgson
This might help in limiting the current supplying the streamers some of the higher power resistors on the output transistor biasing might need some of the better quality types from the better suppliers for size and wattage  1W should do (depends on supply voltage and higher voltages might need experimenting with.
NickZ
Quote from: Hoppy on September 16, 2017, 05:12:00 AM
Agreed. That's not the purpose of heat-sinks.
Have you tried looping back for self-running whilst in the chaotic 'effect' mode?
   Hoppy:  No, I have not tried to loop back, yet.  The avalanche mode is not a use able alternative, as far as I can tell.
   I am working on trying to get the effect back after the snubbers were installed. Under 200v the chaotic mode is not present.
Although I do get some interaction between the Kacher and the induction circuits, without going into the chaotic mode.
But, Radio Moscow has not been heard since.
   After re-viewing Geo's videos it appears that he is not going into the chaotic mode. As his fets are staying cool, which is not the case at over 200v. And he does not even use nor need fans. But, without seeing what's happening on a scope, it's going to be hard to tell what he is doing. In any case, he does not show any over-unity, as yet. His PS is outputting 24v times 5 amps, which is 120w. That's it and that's all. No matter how many bulbs are used. Yet he does not have nor show 120w worth of light (lumins). Which I've asked him to show by placing a grid lit 100w bulb, next to the device lit 100w bulb. He won't do it, as that would prove my point. He used a 50w bulb instead, lit from 120w input source.
   We are all still outputting way under unity, and not able to self run, as yet.
PolaczekCebulaczek
just a quick question regarding overall theory of this contraption, are they any standing waves and out of phase stuff inside the grenade coil?
Hoppy
Quote from: NickZ on September 16, 2017, 10:01:15 AM
I'm sure you are right, as avalanche is clearly destructive. I just wondered if by loop backing in chaotic mode, would kick your device into self-running and out of chaotic mode, as spiking would be immediately suppressed. Very unlikely to self-run but anything is worth a try with this contraption.
AlienGrey
Quote from: PolaczekCebulaczek on September 16, 2017, 10:25:04 AM
just a quick question regarding the overall theory of this contraption, are they any standing waves and out of phase stuff inside the grenade coil?
Hi PolaczekCebulaczek  I don't want to appear rude but if you go back in the database of this thread you would find it extremely very beneficial to do so.
I'm the type of guy who likes to do my own experiments in the field of trying to learn by destructively rebuilding circuit sections and testing,  but I will tell you this, I tried a CPU VDU and I couldn't get any joy you would do far better sticking to high gain (permeability) toroid wound experiments to achieve your goal of 'standing waves and keeping wire length to a harmonic length at all times and guessing nothing. Going off on your own like some do 0on here will get only money wasting and heartache, good luck.
Allen
