0 Members and 311 Guests are viewing this topic.
AlienGrey
Quote from: NickZ on September 17, 2017, 06:53:25 PM
    Lost Bro:
   Now if you can reach Radio Moscow you'll be in like Flin.
They only transmit on the second Tuesday of every week.
  Apecore at one time had the right sound, what happened with that?
   Maybe I could only get the signal during the solar activity last week and the record-breaking 3 hurricanes.
   But, I'll continue trying. Using the properly tuned snubbers circuits is very critical to getting anywhere with this.
How many Tuesdays are there in a week where you live? ;)
By the way storm and solar activity,  the frequency stabilization can change a few kilohertz be prepared to hunt up or down a few kilohertz.  Also, something big is supposedly going on around the 21st this week, so have fun.
Lost_bro what happened on your board?  I used 1K5 devices had no trouble since my first tests they clip but no heat so won't be changing, Are we talking about reverse flyback protection diodes?
Allen
Hoppy
Quote from: AlienGrey on September 18, 2017, 03:46:47 AM
By the way storm and solar activity,  the frequency stabilization can change a few kilohertz be prepared to hunt up or down a few kilohertz.  Also, some thing big is supposedly going on around the 21st this week, so have fun.
Allen
Its the 23 Sep - claimed start of the Tribulation Period - long overdue!
AlienGrey
Quote from: Hoppy on September 18, 2017, 03:58:32 AM
oh yeah! the planets change sine then too! Virgo to Libra (man and machine).
7 years of it, if we are all still around by then. ;)
http://www.watchfortheday.org/1260tetrad.html
lost_bro
Good day All
Noticed that no-one has posted anything for a few days now, so figure I would post this:    https://www.youtube.com/watch?v=OHlQ_bI2bmk&feature=youtu.be
I was probing another one of the various Ruslan replication Grenade configurations using a two channel DSO in XY mode, when I found a curious configuration of connections that would give a *Double-Concentric* circle Lissajous pattern.
Lissajous patterns are generated by applying two different signals, one to the horizontal and another to vertical inputs of an oscilloscope (XY mode).
The resulting pattern is a function of the ratio of the two frequencies.
A perfect circle would indicate a 90 degree phase angle relationship between the X and Y inputs on the DSO.
A straight line running at a 45 degree angle from the 1st to the  3rd quadrants indicates a Zero phase angle difference, or *in-phase* relationship between the X and Y inputs of the DSO.
By reversing the connection of the ground line connection to the Grenade, the two apparent pairs of circles could be made to appear _In-phase_ or _out-of-phase_.
The unique and anomalous fact concerning this *Double-Concentric* circle Lissajous pattern is that with a two channel DSO, (while testing a passive device) It should NOT be possible to produce more than ONE circle at a time. Because the generation of a single circle requires the use of both channels, so the appearance of a *second* circle carries interesting implications.
Considering the groundline interaction is catalyzing / amplifying this effect, I would offer speculation that some species of reflected standing wave is involved.
take care, peace
lost_bro
Void
HI lost_bro. Were you driving the grenade coil with just one waveform,
or with two waveforms? One driving waveform to the 'inductor' winding (primary winding)
and another waveform to the 'antenna' winding, or what exactly? Anyway, you can see the combining
of two different waveforms in your time domain scope screen shots, so I would make a guess
that the two different lissajous patterns are due to the two different waveforms at two
different frequencies on the grenade, whatever their origin might be.
I have a commercial AM radio station transmitter site not so far away from where I live, and it
shows up on some of my coils and on my ground wire when I am experimenting sometimes, and
can make things harder to analyze because I have this extra waveform showing up in the approximate
1MHz range that is actually due to a local AM broadcast station. :) Not saying that is what you were
seeing in your test, but just mentioning it as it is something that had me scratching my head in the
past wondering where this high frequency waveform was coming from that showed up
quite noticeably in some of my tests, even on my earth ground wire. When I compared the measured
frequency to the frequency of some local AM broadcast stations, one of them matched closely. :D
All the best...
