0 Members and 351 Guests are viewing this topic.
NickZ
   Ok, thanks for the comments guys. I'll see what I can do with what I've got on hand.
   Belfior: Thanks for the offer.  I'll let you know about sending the resistors.
   Hoppy: When I disconnected the RC snubber network, I got RM back. Careful tuning is in order to get the big peaks down but not too low, or RM won't be heard. Without RM there is no magic, no matter where I adjust the 494 controllers, place ferite, or use my magnet on the yoke core.
   AG: Without the resistors, there won't be any fets left alive. Yes, the heat is wasted, but, it's also wasted without the resistors as the fets will heat up and waste the heat in the same way.
Hoppy
Quote from: NickZ on September 27, 2017, 10:46:19 AM
As I pointed out earlier, chaotic mode is needed for RM. If you feel that this is the magic tuning point, then forget about good electronics practice and work outside the box. I gave up at this point as all I saw was a big increase in current draw, with little increase in output. However, unlike you, I did not have the patience to work at it. You may be able to keep the RM and ward off smoke by using a carefully selected TVS diode and big heat sinks and / or fans.
Void
Quote from: r2fpl on September 27, 2017, 03:54:38 AM
Is this possible ?
Hi r2fpl. I don't know what is the correct interpretation of Kapanadze's style of 'grenade' coil,
but Kapanadze takes steps to hide what he is really doing, so some things that you see in his
devices are there to try to mislead or confuse people.  ;D
One reason people may be having a lot of difficulty replicating the Akula/Ruslan setup is
the configuration of grenade coil as explained by Ruslan previously, which a number people have
been trying in the last few years, may not be entirely correct or maybe not a complete picture, or possibly
it is just far from an ideal configuration so very tricky to get it to work. Some people seem to be trying
other 'grenade' winding configurations now, so we will see if that yields any better results for anyone.
As I mentioned recently, Daly just used regular wound air core coils and was apparently able to make
his setup self running, so the exact winding configuration of the coils does not appear to be critical
to getting OU out of these types of setups, although certain specific coil configurations may be better
than others.  It seems to me however it is likely that there is something else besides the specific
coil configuration which is key to getting the OU effect. I continue to experiment with different approaches
as well. :)
r2fpl
Quote from: Void on September 27, 2017, 02:33:31 PM
As I mentioned recently, Daly just used regular wound air coils and was apparently able to make
as well. :)
Hi, Void,
Maybe secret is not in coil ?
Possible uses: radioactive cobalt. Plexiglass stopped this radiation.
TPU Steven Mark probably too uses.
Only speculation.
Void
Quote from: r2fpl on September 27, 2017, 02:53:10 PM
Hi, Void,
Only speculation.
Yes, anything is possible. Some people have thrown around the idea that you must have
a certain type of ferrite in the toroid, otherwise no joy, but I don't know. I think it is good
to keep an open mind. Someone out there may well hit on a working configuration sooner
or later. :)
