0 Members and 445 Guests are viewing this topic.
Hoppy
Quote from: NickZ on October 06, 2017, 09:48:45 AM
  Hoppy:
  The problem is that the better optimized the 3t/cap circuit gets, the brighter the bulbs are, and the higher the heating on the snubbers. And not the other way around. Using a 50w bulb, or even a 10 to 20w bulbs, there is little heating, but that's not the results that I'm after. I need to get all 3 or my 200w bulbs going at once, at least like I showed on the video, when one of my fets blew, at least.  But, without blowing the fets.
Nick,
If you have optimised the caps, then it looks like you may have a high leakage inductance issue with your yoke.
NickZ
   This is the second yoke that I've used, both yokes are would differently, to test their heating and efficiency between them. I have an almost 4 inch yoke on, and it can crank some amps. But, I'll tame this beast, yet.
GeoFusion
Hi all  ;)
https://www.youtube.com/watch?v=_wKZ9ehCciU
something for the view here.
The effect as how it should be. was very hard to get on recording since it was hard to maintain effect.
but moments after resolving the values of caps needed and finally did a good one.
Tuning is very precise , the raw tuning with these variable resistors on the TL494 board need to be refined.
When the output or series resonance is shorted the amp meter goes almost 0 amps on scale when connecting more heavier load
the amps go down instead of going up. ;)
Cheerz~
Hoppy
Geo,
Thanks for posting your videos. From viewing the tests you conducted in the last two, I'm now fairly happy that I technically understand the various effects observed. No need now for a better ammeter scale resolution as far as I'm concerned.  ;)
