0 Members and 692 Guests are viewing this topic.
Void
Quote from: AlienGrey on October 09, 2017, 05:06:22 PM
This one
https://www.youtube.com/watch?v=3ehz4MT8ec8
It's all Cepren's work
Hi AG. I have seen that Andrian Guska video before, for which his device seems to actually be
based very closely on Ruslan's early replications of Akula's device using a kacher.
I was asking which Stalker video I should watch in which he shows a (supposed) self runner.
Unless you are saying Stalker and Andrian Guska are the same person?
AlienGrey
this data might be of help to some of you while winding this device, of course the frequency with your catcher might be different but i'm sure you could build your own coil winding data base coil winding relationship.
Note formula data rounded up to 2 decimal places rather than the full cut and pasted calculation being listed.
Also be aware if using this formula relationship the coil winder might find it hard to be able to archive
Katcher self osculation very easily unless using a VFO driver of some kind when the coil windings have been reduced
to 1/2 wave or less.
http://www.procato.com/calculator-wavelength-frequency/
Wave length to  meters
1.67mhz   179.52  meters
3.34mhz   89.76    meters  2nd  harmonic  1 wave
5.01mhz   59.84    meters  3rd  harmonic
6.68mhz  44.88     meters  4th  harmonic  ¼ wave
8.4mhz    35.69     meters  5th  harmonic
10.02mhz  29.92   meters 6th  harmonic
11.69mhz  25.64   meters 7th  harmonic
13.36mhz  22.44   meters 8th  harmonic
15.03mhz  19.95     meters 9th  harmonic
16.7mhz    17.95   meters  10th  harmonic
Version 2
38 metera    7.889275210526315  Mhz
19 meters    15.77855042105263  Mhz
This one
I suggest you watch them all, you have much to catch up on.
Grrr. Once again.... The English letters C e p r e n are approximations of the Cyrillic letters  С е р г е й
and in English this is pronounced and spelled "Ser-gey" or Sergei, not "Sep-ren".
http://learningrussian.net/pronunciation/transliteration.php
Quote from: AlienGrey on October 10, 2017, 02:24:20 AM
1.67mhz   179.51644191616765  meters
3.34mhz   89.75822095808383    meters  2nd  harmonic  1 wave
5.01mhz   59.83881397205589    meters  3rd  harmonic
6.68mhz  44.87911047904191     meters  4th  harmonic  ¼ wave
8.4mhz    35.68957833333333     meters  5th  harmonic
10.02mhz  29.919406986027944   meters 6th  harmonic
11.69mhz  25.645205988023953   meters 7th  harmonic
13.36mhz  22.439555239520956   meters 8th  harmonic
15.03mhz  19.94627132401863     meters 9th  harmonic
16.7mhz    17.951644191616765   meters  10th  harmonic
Version 2
All this demonstrates is that your calculator can spit out meaningless numbers after the decimal point. This is FALSE PRECISION. I challenge you to tell the difference between 7.889275210526315 MHz and 7.889275210526316 MHz, or  between 17.951644191616765 meters and 17.951644191616764 meters using any actual measuring device available to anyone.
The general rule in these matters is that you CANNOT have more precision in your result than the LEAST precise number that goes into the calculation. So saying, for example, that 19 meters  =  15.77855042105263  Mhz is simply wrong, even though your calculator might spit out all those numbers as the result of a numerical calculation. The best you can say in the reality of actually measured quantities is that 19 meters = about 16 MHz. Or 19.00 meters = 15.78 MHz. Or that 19.000 meters = 15.778 MHz. Get the idea? This is the concept known as "significant digits" or SigDigs for short.
Avoid false precision, as the more digits you have in the result of a calculation involving measurements, the more likely you are to be wrong.
AlienGrey
Quote from: TinselKoala on October 10, 2017, 03:01:08 AM
Tinsel nice to see you are back and to see you taking an interest in this tread.  ;D ;D
I'm sorry so many decimal places and i didn't use a calculator at all just cut and past  ;D obviously no one would use or be able to use that accuracy but never the less one needs to be at a few MM accuracy or you don't have the correct wave length and then no resonance to carry out meaning full tests, that over how ir the free energy coming along in the Tinsel work shack, any thing good ?
PS I don't have a problem with Cepren or Sergey or Enola Gaye for that mater as they are all handles and people need to find his youtube files and vids, if i was to put Sergey Stalker no one would find it. Also I don't want to get involved in East West bickering or the New world order or it's global control on here or anywhere else if thats the problem, Oh happy days !
Any way Kind  regards and I wish you well AG
