0 Members and 81 Guests are viewing this topic.
NickZ
    Itsu:
   I understand, and can't blame you. That has been what most everyone thinks, also.
  I will never the less continue plodding away in the dark. You never know... All I'm looking for is a little light at the end of the tunnel, to know which way to go, or what to do.
  The basic principle is what I'm looking for at this time, and I still don't have a clue.  Need help, like we all do.
  We may have to wait until someone that can be trusted, comes along, and gives us a hand.
  Akula is probably spending the money from the sale of his device idea, now, to care much about helping anyone. He never did answered the e-mail that I sent him, so I don't know what more to do.
  T-1000: I'll try to do something to correct what may be needed in your diagram, when I know more.
In the meantime look at the last picture you just posted and see how the red yoke coil is connected at both ends. As well as how the rectified 220v is not going to the big air coil. Akula said it was only connected at the bottom of the big air coil to ground, and at the top of the air coil to the bulbs, nothing else was mentioned.
   Nice clean diagram, in any case, and you may be right, who knows.
  Maybe Akula will show up again on Skype, or one of the forums one of these days, as well.
T-1000
Quote from: NickZ on June 05, 2013, 05:23:38 PM
  Look at the pictures above, the circuit is not like the diagram. There are several things that I see in the diagram which are not like what I see in the videos. Like the rectified 220v is not going direct to the big air core. There is also a grey wire going from the inverter/rectifier back to the battery area, but I can't see it clearly.
Still checking on what I might missed. Can't see where choke is connected unless it is hidden with white cable going on bottom of big transformer from red wire of yoke. Also I noticed the edge of big transformer is reflecting so probably it is metalic after all. Here are more pictures for this case:
NickZ
   Good pictures!  Can you see that the red yoke coil wire is connected to the black wire from the rectifier, on the right side, and the other end of that red coil is connected to the yellow wire that goes to the driver board? The white wire under the yoke is one of the unknowns to me, as well as the grey wire from the rectifier to the battery area.
  If you study Hendershots diagrams he is showing the center choke as a coil wound on the outside of  capacitor, and each end of the coil connected to the two capacitor connections (+ and -),  which are then both connect to a transformer located outside of the big woven air coil. So, his choke coil/capacitor is connected to a transformer.  Maybe Akula also connected the choke to either the air coil, or the yoke. As I don't see how the choke would be able to do much isolated, just connected to a small tuning capacitor. But, that is how is appears in the hand drawn diagram, IF that is correct.
I think that the metal strip on top of the air coil is only a small piece of aluminum, but maybe is goes further down. I've lined my air coil with an aluminum liner inside with open ends on about 70 % of the inside of air coil surface. I think the choke is only a pvc pipe former with about 40 turns of insulated wire on it, and maybe that small tuning cap.
T-1000
Quote from: NickZ on June 05, 2013, 10:51:45 PM
In slide3-2 and slide4 the reflection of white wire is seen on capacitor. Also the yellow wire passes yoke over top to down near capacitor and continues to grounding. Not sure if it is connected on that point.
The white wire from red coil of yoke goes underneath of second transformer and this is only one place where I could assume the choke connected inside of large transformer (as akula said "output choke in magnetic field" in first video part). Not sure if there would be free oscillating LC inside of big transformer like it was in Hendershot circuit as that would require capacitor which wasn't seen in video.
The slit looks like aliuminum due reflective surface but the other metal might be in place as well. Not sure too how deep it goes from top inside of transformer.
If you use one of my diagram drafts the bulbs will be lit straight from inverter with 25Hz frequency. The induction heater effect and way how additional looping coils are connected might do the difference to power delivery. That needs to be tested.
NickZ
  There is a metal strip inside the air coil, and there does seam to be something else inside the choke as well, like a small cap maybe wrapped in tape or paper.  Still there are many unknowns to effectively replicate, but I'm doing what I can as I get more information, even though I don't know what is really going on yet.
  I'm hoping that there will be other Akula replication and further information from the Russian forums soon, also. Otherwise it's a hit and miss deal. But, I'm also hoping to hit on it, even if by accident.
  Thanks for the pictures and diagram.
  I added a bit of contrast and sharpened the focus slightly to your image, to see the colors better.
Look at the grey wire also from the rectifier to the battery area.
