0 Members and 1753 Guests are viewing this topic.
AlienGrey
Hoppy back on page 5 you published this circuit 5 or 7 years ago, any idea why you didn't get it to work ?  ;D ;D
Also in the Aquarium video you said half the stuff in the box wasn't required can you say what bits they are ?
Best regards  AG
Hoppy
Quote from: AlienGrey on October 27, 2017, 02:53:45 AM
Best regards  AG
Blimey Alien, I was a much younger man then just entering the free energy world and eager to find the end of that rainbow!  ;D I was working with Itsu and Verpies primarily on the Daly circuit. The Daly circuit did work insofar as lighting bulbs and producing sparks but like other contraption circuits published to date, to my knowledge, none have achieved self-running in the hands of the builders on this forum.
In respect of the Aqua2 video, my opinion now is that almost all of the bits were just eye candy, as I believe that the device load was powered from a supply external to the demo room. However for Nick's sake, I do not wish to elaborate by getting into further discussions on devices I consider to have been faked.
AlienGrey
Quote from: Hoppy on October 27, 2017, 04:01:41 AM
The info as I understand it you made something like it, the thing is did you pulse the EHT like a care alternator or did you have it free running ?
AG
Hoppy
Quote from: AlienGrey on October 27, 2017, 07:12:30 AM
AG
Like car ignition with cap.
Void
Nick, Itsu, here is the current waveform on my toroid center tap wire (V+), with V+ set to 12V.
You can see current spikes on the current waveform where the non-dissipative snubbers
are limiting the switching spikes. For a 'load' for this test, I had a shorted two turn secondary.
It looks like there may be something wonky with my test setup. :)
The V+ current is not showing as balanced for each MOSFET.
The current magnitude is a lot higher for one MOSFET.
It looks like I will have to do some investigating to see if I can figure out
why the current is so unbalanced for each MOSFET. The Gate waveforms
should be a pretty close match for each MOSFET, but I will double check.
I will try rewinding on a TV yoke core instead as well and see if there is any difference.
Maybe using the shorted two turn secondary winding is causing the current imbalance, but I am not certain.
The yellow trace is of one of the MOSFET Drains.
The blue trace is the current waveform on the toroid center tap wire.
My scope current probe is not very high quality, so the absolute magnitude of the current may not be very accurate. :)
Isu, maybe your current shows as a sinewave because you were tuned to resonance
in the series resonant loop on the secondary...
