0 Members and 1022 Guests are viewing this topic.
NickZ
  It may be possibly that in Akula's choke there is also a white paper separator between the aluminum sheet, and the choke.  As in one video, one could see the metal sheet going down the tube and covering most of the inside diameter, if I'm not mistaken,  I'll look for that.
   He may also be covering the sheet in his latest video, and it may be there also, but not visible. As in the Hendershot's diagrams there is NO external input source.
  There has to be more than normal electronic circuitry going on here, or it wouldn't work like it is.
What is this effect???   He mentions,  "I tell you a secret".... the Earth magnetic resonance...
TK also mentions, the source is the same thing as what Tesla was talking about, ambient energy.
NickZ
   T-1000:
   In your last picture you can clearly see that the center tap of the yoke if going to the drive circuit, and not to the rectifier. From that rectifier one dark wire is going to the driver board, and another dark wire is going from the battery area behind the air coil and also to the driver. So, they are maybe the positive and negative input source to that driver. But, the center tap is not directly connected to the rectifier. The red yoke wire is connected to the rectifier, even if the other end is not connected to the yellow wire, but I think that it does look like it is connected to the yellow wire. Look at my last picture.
The big air coil is not connected to the rectifier. It goes from earth ground at the bottom, and at the top of the air coil to the bulbs, like he says, and isolated from direct contact to anything else. That part works like that, at least it does on my device, as the bulb lights connected to the air core top wire,  with no direct contact to anything else, but to close the circuit back to ground it works better.
T-1000
Quote from: NickZ on June 06, 2013, 01:21:26 PM
   T-1000:
One to driver board from rectifier and another to the ground. The driver part where this wire comes to has capacitor and choke probably for smoothing and filtering purposes. Obviously the microchips are not fed by 220V so the logical question - what it is for? And when looking back akula's on induction cooker experiments the answer is obvious. :)
I think that's enough of detective work from me, back on basic principles on where second source of energy is coming from to that circuit. The NMR/free electrons sucking from external source or any other second energy source should be narrowed down. My bet is on NMR there ;)
NickZ
  The driver board can be getting 220v Dc from the rectifier, then is dropping that voltage by the brown ac cap on the board to a needed voltage.
I know where the energy is coming from, but I don't know how to obtain it from the ambient yet. Therefore much more detective work is needed for me to replicate. I am working on this 24/7, even when I'm at the beach, and even in my sleep.
  This is what I see, of course it is probably also not right. But I'm trying...
forest
Very good NickZ  ;D  What did you took so long to realize this simple scientific fact ? "Columbus egg factor"  ;D ;D ;D
