0 Members and 587 Guests are viewing this topic.
NickZ
   soliman:
   Please remove or resize your last two images, as they are too big, and mess up the thread here.
   EDIT: Thanks for taking care of that.
   I placed an aluminum tube inside of my grenade, and yes it raises the output slightly, but this causes my mosfets to get hotter. As the voltages can get over 200v at the best resonant point. Adding ferrite inside the grenade did not help, at all.
  Adding ferrite inside of the Kacher does help, to increase the Kacher's output,  but does not change the Kacher frequency, which stays about the same.
   What I see when tuning to the staticky fried chicken mode, is that yes, the voltages go up, but the expense of the output at the bulbs, which goes down. Can you check about that on your device and let me know if your bulb's output also goes down, or not?
   Do you use a load when you're doing these tests?
   If you can make a short video, that would be good.
   I try on different loads between 10w up to 600w. Each additional bulb raises my voltage readings, while at the same time dimming the previous bulb.  I tune not by the going for the higher voltage readings, but by the higher output (lumins) at the bulbs instead. Which is what is most important to me, with the output in sync, while running in the silent mode. Which is right next to the fried kichen mode, but it has higher output at the bulbs, and does not heat up my fets, like the frying chicken mode, or like most ringing sounds can. Anything but the silent resonant points seam to be a problem for me, so I'm discontinuing to tune for that type of signal. And will now tune to the highest lumin levels, while running in a non avalanche, silent mode, instead.
Grumage
Quote from: AlienGrey on November 02, 2017, 03:38:01 PM
Hi Graham  some I phones wont let you chop down pics rumor has it,  :)
idn't know this bit about a HV  (Akula replication attempt I had two slit Aluminium tubes separated with an A 3 lamination pouch these capacitor plates were then connected in parallel to an inner coil of 650 turns)
So what was it's resonant frequency and its capacitance and the coils inductance ?
Should be interesting Verrrrry  :o 8) 8) 8)
also in your inner coil, was it tuned to 1/4 wave by any chance ?  That might be difficult to attain with out a scope and signal generator. Also did you try to pulse the katcher or high voltage winding  thing at it's resonant frequency or one of  it's harmonics ?  I'm not sure rely  how that device of your is suppose to work but resonance tuning would be one way to collect the energy, if you ever find a way of producing it  ;D ;D
Mr AlienGrey.
Arunas might confirm this as a Mark2 device.... The inner cap/coil would effectively work as an indirectly induced Kacher but we were in the infancy days back then. I really do feel that the continuous and dogged determination given by Nick, GeoFusion, Hoppy, Itsu, yourself and Co, has brought us closer.
If memory serves the self resonating frequency was in the 80Khz range, no attempt was made to tune it though.
Nick.
An unslitted Aluminium tube would act as a shorted turn increasing current draw. Was your tube slitted?
Cheers Graham.
AlienGrey
Quote from: Grumage on November 02, 2017, 04:23:00 PM
Mr AlienGrey.
Nick.
Cheers Graham.
I fortunately back then could not see where the energy was coming from  ;D and was working mostly 7 days a week so I left well alone  :-[
But later a work colleague suggested we make the Delamorto device (not sure about spelling) device it had a plastic tube with a long slit down a water pipe down the middle and a ferrite rod aerial in side that. It was later replicated by Woopy ? but he didn't use a ferrite rod as i remember on you tube, but ours lite a 100W bulb quite brightly if built correctly and ours did, but we didn't know how it worked for sure buy it wasn't Free Energy little as it had losses and we  did not know back then, and some one on here kept saying you can't have free energy on here :'( :'( but recently Mr Tesla re published a patent (complicated to understand all the criteria for a person like me  ;D ). or its protocol ! but others must know the secret  ;D  but wont admit to it !
Found this the question is who said it ? Neither Woopy, nor Delamorto have ever shown a self runner.  Nor has anyone else using that type of kacher circuit. I wonder why that could be ?
https://www.youtube.com/watch?v=94yCfy8z4lc
https://www.youtube.com/watch?v=3ZN1zFzgQkk
NickZ
    Grum:
   Yes, the aluminum from a soda can was cut and slit so as to leave a gap.
   Adding magnetite magnets into the yoke can also raise the running voltage, and control the ringing wave forms, as well as to raise the draw. Magnets can also help in tuning, at times.
GeoFusion
Hi all :),
There will be some uploads by tomorrow  but want to arrange some stuff befor I do so.
The Dead time controller will be modified yet again just to see what happens when increasing values of capacitance and resistance
One thing I want to point out is when reaching white arcs ( Disruptive mode ) be careful, shocks the hell out of you.
not burning sensation anymore like those plasma corona arcs.
T-1000,
I managed to place the Ultra Fast Diode in series over the Emitter side of the transistor of Kacher. :)
There are interesting changes!, Placing ground wire to at the antenna seeing the white arcs able to be longer,
I feel shock waves now !... and got shocked while touching one of the heat-sinks of the mosfets ;D ,
which never happened befor. The video where he was telling it was vibrating, this tells it all.
The disruption stepped up and the tuning with the pots were changed, having a more sensitive areas of leaving it
in the mode. tomorow will add extra 2.2nF cap to the Dead time controller. ;)
Results of currrent coming up :)!
Nick,
Try to put a ultra fast diode from emitter transistor leg connecting anode - kathode to kacher board
  Emitter -->-- kacher board emitter socket :).
Thise might change the game a bit and get  some different results.
Soliman,
I did try to use aluminum slit tube inside the grenade once but was never recorded.
That what you see inside the Grenade was not Aluminum but just PVC plastic reinforcement inside.
Up till now never used aluminum for greater output, but it might be needed in other setups that will come along ;).
With a good Electric field being disrupted or lets say, abrupt collapsing fields of HV, would create good current on the AL. slit
Of course the Aluminum idea is great to harness and have usable current coming out ;).
Hi Grum :D!
Long time. how's everything?
    CHeerz~
