0 Members and 128 Guests are viewing this topic.
Hoppy
Quote from: NickZ on November 11, 2017, 10:26:07 AM
  Well Hoppy, the reason that both you and Geo were noticing a stronger interaction is because you were using much lower wattage bulbs. Or did you have a 600w load on?  NO...
Like you, I tried various power rated bulbs, even including a 1000W halogen strip and in all cases , I could see a strong interraction effect, albeit that the higher the wattage, the less light output. I could almost extinguish the bulbs with hand capacitance on the Kacher. As I have pointed out several times in the past, I traced the effect down to the push-pull being affected by the Kacher's interference on my supply rail that was common to both the Kacher and push-pull. It was on this realisation, that with help of instrumentation, I showed that the 'effect' was not indicative of anything special relating to greater throughput efficiency.
AlienGrey
AlienGrey
Quote from: Hoppy on November 11, 2017, 02:00:05 PM
Like you, I tried various power rated bulbs, even including a 1000W halogen strip and in all cases , I could see a strong interraction effect, albeit that the higher the wattage, the less light output. I could almost extinguish the bulbs with hand capacitance on the Kacher. As I have pointed out several times in the past, I traced the effect down to the push-pull being affected by the Kacher's interference on my supply rail that was common to both the Kacher and push-pull. It was on this realization, that with help of instrumentation, I showed that the 'effect' was not indicative of anything special relating to greater throughput efficiency.
Hoppy I had much the same effect when I was testing and tuning although i was getting a ferrox resonance oscillation peek at certain frequency's increasing with an earth. so its not uncommon, and in a thunder storm it was brilliant.
apecore
Hoppy i agree 100%.
It would be easy to see if the power IN (Amps) to the pushpull device would increase at the moment the kacher is activated.
Seems to me the only way to clear_up this chapter about "the effect"
Best regards
NickZ
   Well, that means that it was working, but maybe without the proper snubbers. So it goes into avalanche and can easily burn he FETs. Or not?  You didn't spend much time tuning it, afterwards.
That RM sound, with hand movement affecting the signals means that you were close. With interactions going on.
   But, notice how Ruslan's devices are fairly silent when in true resonance. They seam to run at a higher frequency. One you can't hear.   Maybe a dog can hear it, like 27khz,
