0 Members and 699 Guests are viewing this topic.
Hoppy
Quote from: NickZ on November 11, 2017, 02:19:15 PM
   Well, that means that it was working, but maybe without the proper snubbers. So it goes into avalanche and can easily burn he FETs. Or not?  You didn't spend much time tuning it, afterwards.
Yes, it was working well in terms of the 'effect' and I had no real problem tuning into it. It was at this point that I found that I could disconnect one side of the push-pull and still get the effect. I did not burn the mosfets as I was using TVS protection.
Hoppy
Quote from: apecore on November 11, 2017, 02:15:49 PM
Hoppy i agree 100%.
It would be easy to see if the power IN (Amps) to the pushpull device would increase at the moment the kacher is activated.
Seems to me the only way to clear_up this chapter about "the effect"
Best regards
Yes, this why I keep on to Nick about the importance of monitoring supply voltage and current to get a good handle on power consumption. In my opinion, the 'effect can only be considered significant, if it can be shown that it improves the device efficiency. In my case, I could see no evidence of this.
AlienGrey
GeoFusion
Hi all :)
About the device, Just a recap on some what I experienced and some good tips.
The pushpull or any other HF drivers for mosfets to able to do the same action and I say,
just make sure there are no filter caps right after the IC (TL494 as example) which makes freq for you which feeds the drivers for the Fets
on the driver board, that kills the operation completely. This is the reason why I shared the exact same diagram long time ago.
the TL494 and the IR2110 config.
The point of output.
The Kacher or better to say Tesla coil is what manifests this energy at the output. More to say, has the full control of this energy which we
all are looking to see manifest at the output.
What I do believe now is that small tweak recently I did with closer antenna to
bifilar inductor is what made me to understand this more clearer also. ( this is only for this method , there are more ways )
Imagine the tuning has to be such condition with Antenna's harvestation of the charged particles ( Ions/,radiant and positrons which are anti electrons ) and having it to be right in the zone of the magnetic field which the bifilar inductor has generated which it will resonate to the antenna incoming charges,
(not the full resonance of the bifilar it self )
distance of Antenna  close to the bifilar is crucial depending the Kv range it produces.
This made the difference in my latest recording about the test that has been done without 28T from toriod/yoke and only the 3T series.
By this time it is already shown on video and even scope readings on what we expect what kacher should be doing.
Since it calls upon the charged particles being excited by the interruption cycles of
the Tesla coil/ Kacher operations. So the Cycle needs to be interrupted, (Dead Time).
Also repeated so much times per time to manifest it even more.
So it should not be generating normal Sinus waves, but interrupted ones at the peak of each and cut off after and repeat.
Better to say to generate spikes.
With that new dead time controller I am able to get a bit more lumins out from that 300W bulb in previous recording.
This is only Tesla coil at work here.
The rate of power into the series resonance coming pushpull /yoke to 3T series cap  which is generating the HF magnetic field is
insufficient to even light or even burn the filament of the 300W bulb. Also already shown on recording.
Right now there is also greater white arcs  present and they do not only burn but give nasty shocks.
Regular setting is pure plasma stream which burns.
Look, if the kacher can produce just abit this " white arc " you will see light manifestation. which I had many times befor.
The amount of amps IN with kacher determines  the amount of turns of Primary and diameter of copper if to see increase of decrease.
The IN amps can vary in many ways depending the setup.
What's interesting here is when the effect is running, the amount of Amps IN is set amazingly to a point which I still do not understand fully
and what happens is everytime to put load it will show where it will not increase Amps IN
but it shows that it has a threshold until where it will  start to decrease Amps IN  after,
so the  more load you add the lesser Amps IN you will see at IN and this is where you can determine
the amount stored energy it created/ harvested and accelerated within the field of control.
Think I shed some more light on the subject to understand what we are looking for.
             Cheerz~
Hoppy
Quote from: GeoFusion on November 11, 2017, 11:02:12 PM
Hi all :)
             Cheerz~
Hi Geo,
Thanks for your update. Read up on LC tank circuits for an explanation.
