0 Members and 1447 Guests are viewing this topic.
stupify12
Quote from: Hoppy on November 12, 2017, 04:53:03 AM
Hi Geo,
Thanks for your update. Read up on LC tank circuits for an explanation.
The Tesla bifilar coil should be considered as COIL + Capacity its a form of TANK Circuit that is design to resonate on its own. That coil will freely vibrate to its own resonant frequency when induced from any suitable primary induction coil, whether its arbitrary frequency or resonant driving primary.  When we can get the resonance on the Bifilar capcoil then it will vibrate on its own in a longer time before it dissipate.
Just sharing.
Will
NickZ
   Geo:
   Have you connected the rest of your system up? Such as the 28t coil, tuning caps, rectifier, etz...
   Can you show us what your voltage readings are at the output bulbs, and your TL494 running frequency, Kacher's running frequency, etz...
   My device works a bit differently, and can light the big bulbs on just the induction circuits, no problem. The nearness of the yoke to the grenade coils makes no difference on my set up, and also the hand movement can't completely kill the output, either. Nor can the hand movements near the antenna make as big a difference, as on your device.
  Also, my voltages at the TL board (drains) go UP with each added bulb, also the amp draw goes up, while the light (lumin levels) at the bulbs goes down with each additional bulb. I'm mentioning this as a comparison, to try to understand what is happening and why these things are happening, and what to look for and tune to for the best results.
AlienGrey
Quote from: stupify12 on November 12, 2017, 08:00:39 AM
Just sharing.
Will
Hi I'm a bit confused by your post could you please explain some of the vagueness in your post please, is the bifilar device (as i'm sure many have not wound the yoke in that fashion) referring by any chance to the Ferrite yoke or Torrid and whats a cap coil please explain? I'm sure your post is of interest to many, once some of us understand the translation.
Also I have just noticed in Geo's post he appears to refer to the 'bifilare' winding as part of the grenade, I'm still a bit confused here as no part of the grenade is intact bifilar wound as such any chance we can define which section of the grenade is bifilar wound ?
Bifilar wound the winding of two coils wound  side by side with the strands side by side see coil, see illustration so as not to
cause confusion.
kind regards
Many thanks AG
GeoFusion
Hi AG,
Check the pic below, that's the Bifilar ( Tesla bifilar ) I was talking about.
see the Purple highlighted box ;).
Cheerz
AlienGrey
Hi Geo
Many thanks for clearing up that valued bit of information.
Mine is wound just like that, however i did insert a space between the katcher
and that winding you refer to with some 3mm strimmer PVC to try and keep the heat down.
If that is any help to any one.
regards AG
