0 Members and 2030 Guests are viewing this topic.
NickZ
  Hey guys:
  Not much going on here lately.
  I've been trying to clean up my act. I'll resume testing shortly.
  My wife said that I was taking up too much room on the kitchen table. So... I gave it a cleaning and some reorganizing.
  But, the camera on my phone seams to be needing a lens cleaning also, as the images are getting blurry.
  Any ways, just trying to keep the thread up.
        NickZ
plaxius
what is the frequency relationship between kacher and pushpull ?
Is the frequency of the kacher really important? I have seen different configurations with flybacks and other high voltage transformers but it seems to be more important the synchronization with the push pull.
AlienGrey
Quote from: plaxius on November 23, 2017, 04:53:29 PM
Hi I wouldn't get too carried away with this design if i were you I don't know of any one who has got it to work I have experimented with the best of them and the only gain i found or got was from the push pull circuit and that was with an earth and it was from FERRO resonance and the grenade coil.
The Tesla coil is a different kettle of fish not one of the circuits work correctly as they are ac driven and kill any radiant gain.
one or two guys on here think other wise but not one of them shows a working device, read Tesla's patent and you7 will find 2 films by Peter Linderman that tell you everything as far as i can see they know.
The answere to your question is they both have to be in resonance the katcher and the grenade but the drive circuits have stuff missing and its drive circuits are BS
Allen
AlienGrey
Quote from: r2fpl on November 15, 2017, 02:19:27 AM
Void:  :)  I did not know that there was a resistor in the spark plug :(
An Experiment for you (so don't try this at home).
If i can just help you out here, all the ones i have tried have a 10Kohm resister in them, you need to remove it
and replace it with a thick bit of 14 swg or eqiv wire.
To do this you need a plug with a solid top variety into the ceramic insulator, you need to hold the large
metallic base section with some pliers now heat the top end with the gas blow lamp a little at a time
until  the lock-tite bonding fails and you can unscrew the top cap section with some effective pliers.
Tip the end down and the spring and resister should fall out, you should now be able to fix and resemble the device.
You need to screen any cables you run to and from your device or any one in close proximity to you will just love you !!!
It now has no suppression be warned, also do not use this plug in your car or lawn mower as it might damage your
magneto coil and again no suppression be warned.
AlienGrey
