0 Members and 1004 Guests are viewing this topic.
AlienGrey
If I can still find it, it was a few years ago with A.King
Also found a link to Henry  Morays son
Hi looks really old now believe it or not he is asking for help
to recovers his furthers empire of the 20s device and is asking for
70 k for advertising help >>>?? on you tube and  Facebook
First have a look at this guys site ground energy extraction.
https://www.youtube.com/watch?v=K0YO3o4Tu9o
he has a short interesting series
NickZ
   Guys:
   I've tried the earth ground many different ways. Are you saying the dry dirt is a better conductor than water which is on soggy earth? In any case I have tried all different ways, including what you are suggesting. And don't see much difference in the way the device works.
Remember how Tariel buried the radiator, then poured buckets of water all around it.
   Akula has his ground line ending in a metal pipe on soggy ground, next to a water source.
   My ground goes to the dirt at the bottom of my shallow well, but ending in a metal tube. I don't drink that water because it has lots of iron content to it, and taste like a rusty iron pipe. But, it's ok for my tests on the device.
   I've also had my ground lines going to a metal tube that's buried into the ground.
   However, and as I've mentioned, the "effect" by adding a ground line to the device, is only to be noticed at the proper resonance point(s). Otherwise there's no extra gain or effect noticed when connecting the ground line(s) to the device.  At least on my device.
NickZ
  The ground extraction video is interesting. It reminds me of some of Dr. Stiffler's projects.
   The energy is not coming from the ground, but going to the ground, from the battery power source, through the short air space, first. Enough to partially light some leds.
   But, try that with a 100w bulb, and see what you get. Zilch...
lost_bro
Quote from: NickZ on November 26, 2017, 09:38:27 AM
Good day All
Here's a short video:  https://www.youtube.com/watch?v=__Idc66i-30&t=15s
  This is a follow up video to one I made a couple of years ago which showed *ground_current* lighting up a 100 watt incandescent bulb which was placed in series with the SSTC ground line.  https://www.youtube.com/watch?v=wysm0Zxpz5k
  It was suggested that a *ground-loop* was being formed through which the current from the H-bridge Inverter could return to the public power grid causing the 100watt incandescent bulb in series with the Ground-Line of the SSTC to light up.
  I felt compelled to continue because I wanted to know for certain if a *ground-loop* was indeed responsible for lighting up that 100watt bulb.
  In this video the SSTC is powered by a home-made 1000watt battery powered inverter which is running off of a 12VDC deep cycle rechargeable battery. The inverter is running at approximately 21kHz and the output is an AC square wave.  The deep cycle battery is NOT connected to Ground and neither is the 1000watt inverter.  The only ground connection is the 10 meter long ground cable (with incandescent bulb in series) connected from the base of the Tesla Secondary to a piece of Steel Rebar which is part of a concrete footing.
  As can be seen, when the SSTC streamer discharges are the longest, the incandescent bulb is at it's brightest.
  So I will leave it to everyone to draw their own conclusions........
take care, peace
lost_bro
AlienGrey
Quote from: lost_bro on November 26, 2017, 11:53:48 AM
Good day All
take care, peace
lost_bro
the problem here is we need to  view the DC current and the true AC in or the DC voltage in and it needs to be on view
while all this is going on, or it's all lust here say. Thats the problem.
I hope that can bee agreed.
AG
