0 Members and 1216 Guests are viewing this topic.
NickZ
   But, the main question is, what will it take for a device to self run? Not just trying to light a bulb, one way or another.
   As I have three ground lines, one is in the well, the second one is next to the well, connected to a metal tube which is pounded into the ground. The third one is next to my bench but on the ground outside my house.  No difference between them that I can notice on my device. Although the two 37.5 meter ground lines do seam to work a little better than the one (about 6 meters long) just outside my house. But, still.  No cigar.
   Roma used a short ground line on his outdoors demonstrations. Not 40m long. And also was able to show his device self running.
   Another guy could light bulbs using a banana. So, anything is possible.  Or not?
  As these ground lines may also work like some sort of antenna for the device, it's best to go with the long 37 to 40m ground lines, made of thick welding cable.
   Akula's big tesla coil set up didn't do all that well, comparatively, although it was a self runner.
AlienGrey
Quote from: NickZ on November 27, 2017, 11:08:04 AM
  As these ground lines also may work like some sort of antenna for the device, it's best to go with the long 37 to 40m ground lines, made of thick welding cable.
The peter Linderman video Hoppy showed tells you and so does one of the videos in 'radiant_one' thread on you tube watch the first one and work through them.
https://www.youtube.com/watch?v=JAxUJODVMfY
AG
PS I mentioned earlier a Hoppy pointer to a thread, I said i thought it was a voice over by PL I tried playing it again just now err
the voice over by PL had gone Sorry about that. I must have clicked 2 vids at once or the system must have screwed up Further
I see Real player is having some connection problems with errors.
NickZ
   When they can light any bulbs while being disconnect to any man made power souce, then I'll believe it.
   The oscillator circuit in that last video is somewhat similar to what Dr. Stiffler used. And a replication of the Doc's type of circuit could light 100 leds. No external power source.
  Does that mean that the energy is coming from the ground? I don't think so, as they are ignoring the possibility of energy being harvested from the air and going to the ground, instead.
   Akula showed that he could light several big wattage bulbs, while using NO ground line, as well.
But, his circuits would overheat. What does that tell you???  When no ground line is used to light bulbs.
   Geo showed how he could light a bulb that was connected in series to the device's earth ground line. Does that mean that the bulb is being lit from the ground?  NO.
  Peter Linderman has never shown any device self running.  As far as I'm aware.
AlienGrey
Quote from: NickZ on November 27, 2017, 12:46:36 PM
I can think of only one way to do that radiant energy but it's destructive it kills any electronics if not controlled, if the man is holding the bulb he becomes -negativly charged, and the tesla coil vertical top pulls down the charged sky potential so every thing becomes charged but you need HV pulsed DC to do that and to control the Tesla coil device or nothing.
it's in the videos watch them. Peter Linderman is your tutor !
NickZ
   Or, he's just a salesman.
   I've not seen any table top self runner that was using nor needing to use DC for their HV impulse source.
