0 Members and 2452 Guests are viewing this topic.
NickZ
   After watching all the guys that have gotten to that point with no results to show for. That is why I think that that is the case.
   If you really thought that it would work that way, you'd do more about it, than what you have been doing, lately.
   I'll connect up a feed back path, soon, and let everyone know how well it worked out. But, don't hold your breath.
   AG, is full of suggestions and advice, but does he try any of them himself, first? And just keeps pointing to other unrelated devices, which he again won't bother to replicate. That's ok, but it's still distracting from the focus of this thread, and what we are actually  doing here. At least those few guys that are still actually doing something about it all.
  The guys that are just watchers,  just keep watching, while sitting on their hands.
AlienGrey
Quote from: NickZ on December 04, 2017, 09:09:58 AM
  AG, is full of suggestions and advice, but he does try any of them himself, first. And just keeps pointing to other unrelated devices, which he again won't bother to replicate. That's ok, but it's still distracting from the focus of this thread, and what we are actually  doing here. At least to those few guys that are still actually doing something about it all.
Whoooooo!
well as it happens i have been experimenting, I'm pretty sure after the katcher it needs to go into a tripler module to boost the voltage up to a +ve level 3 or 4 kv, Ive wound a ferrox transformer and its fed by 2 fets to give 1.25kv from 12volts, I can get 3.5kv with a 50 50 cycle but it needs to be pulsed.
So as I don't blow my electronics up I'm experimenting with a 12v large relay coil, I made up a variable freq osc to give a triangle wave from a cmos 555 and feeding it into a LM358 differential  amp to give a perfect width control for pulse tests on the relay large silver contacts and coil charge pump circuit not done the charge pump bit yet.
Also perhaps i can find out Nelsons little secret or not as the case might be.
But I should be able to test for correct drive and output gain if any.
AG
Void
Quote from: NickZ on December 04, 2017, 08:03:46 AM
The system has to be able to do more than just barely light some bulbs, first, for it to be able to self run itself.
Hi Nick. I agree that is probably true. It seems not very likely at all that the system will self sustain
when self looping if you are not seeing a very notable OU effect when the system is not self looped.
All the best...
Hoppy
Nick,
I have no real idea how it should be built and tuned for self-running. I'm just throwing in thoughts like others. You have no idea what I've been doing lately.  ;)
NickZ
   Well, Hoppy you do have an idea of how it's supposed to work. Ideas are only useful if they are backed by tests. Each to his own.
