0 Members and 371 Guests are viewing this topic.
r2fpl
AlienGrey
Quote from: NickZ on December 12, 2017, 09:29:55 AM
   AG:
   As mentioned, I have NO problem using the simple Kacher circuit. It works for me. It also worked for Ruslan, Roma, Adrian, etz.
   I have shown the "effect" in a video, with my Kacher/grenade running on the Mazilli circuit lighting 4 100w bulbs.
It was with the same Kacher and grenade coils, as I have on now. My newer and more recent TL494/TC4420 circuit can't seam to produce the same degree of the "effect", as yet. The rest of the device being the same.
    There is no such thing as a narrow pulse, with the simple Kacher circuit. It outputs a sine wave, which I CAN control between 850KHz to 1.1MHz.  The mentioned 13.5KHz lower frequency limit of the induction circuits is controlled by the 102 tuning cap on the TL494, not by the fet drivers.
   None of the guys here that have built the controlable Kacher circuit have shown it working to self run itself, yet.
Or even being able to light several hundred watts worth of bulbs while showing the same "effect" generation. Like 500w to 1000w worth of bulbs.  So, I'll just wait and see what happens with them, before going that route.
   It's best to build something yourself which works, that way you can prove your ideas to yourself. As just throwing out advice without backing it with a working device is not very convincing.
Interesting but what if its just ferro resonance ?  look up 'avalanche' phenomena I sent you see here example https://www.youtube.com/watch?v=Jqptq7A9cGU
NickZ
Quote from: AlienGrey on December 13, 2017, 07:31:48 AM
   I see nothing about "avalanche phenomena" in that video.
  Using either AC nor DC he can only barely light the small bulb.
While I can light a 100w bulb with just my Kacher. And lower wattage bulb even brighter.
  But, the idea is not to light bulbs with HV, but to interrupt the magnetic field, with the HV pulses, instead.
AlienGrey
Hang on a moment  :o
So how much current is your device drawing when its running your full load ?
in the film he is showing the green spark that's the avalanche effect that depends on gap and energy and frequency if you look it up. The effect is donkey years old
NickZ
Quote from: plaxius on December 12, 2017, 06:42:09 AM
[size=78%]Nick, I recommend using a DC-DC buck of this type.[/size]
[size=78%]
[/size]
https://es.aliexpress.com/item/DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-Output-1-5V-35V-DIY-Part/32737337535.html?src=google&albslr=225409384&isdl=y&aff_short_key=UneMJZVf&source=%7Bifdyn:dyn%7D%7Bifpla:pla%7D%7Bifdbm:DBM&albch=DID%7D&src=google&albch=shopping&acnt=494-037-6276&isdl=y&albcp=913280151&albag=47655558845&slnk=&trgt=388120373908&plac=&crea=es32737337535&netw=g&device=c&mtctp=&gclid=EAIaIQobChMI8Z_qkrKE2AIVAlcNCh082AWdEAQYAiABEgJnr_D_BwE
  These cheap converters can only output 2 amps.  Not enough for the induction circuit.
I suppose that it could be used for the Kacher's input by itself, if needed. Probably takes a month to deliver it.
   I'm working on making a 24v battery bank for now out of lithium ion batteries.
   My new PS will be delivered in about two more weeks.
