0 Members and 1756 Guests are viewing this topic.
peper10
Quote from: AlienGrey on December 14, 2017, 08:05:32 PM
D o you know what the values of the components are ?
If you feed that transformer with a SG and look at the output with a scope you get a pinch effect like 2 magnets repelling each other a shock wave effect or vortex
I dont have the Stiffler circuit to play with but I imagine a door bell transformer would work fairly ans a 3mf AC cap to start with..  The spikes can be TAMED and be more like sinusoidal and the SHARP TRANSIENT.has the voltage to support my theory... I would start from there and move up in values of the cap..
peper10
Tell me one thing....   Compare the two circuit and tell me how the first one CANNOT get what the second one with the in serie transformer in the first??
Jeg
Quote from: AlienGrey on December 14, 2017, 05:51:23 PM
If you dont have  the program or the device Ardueno or don't want to spend a fortune on an
equivalent of a pic-chip you can do the same thing with a NE555 and an op-amp and a MosFet driver
and 2 10k pots and very few other components, but if not, but hey don't be surprised if the pulse
blows your micro UP!
Thanks Alien but i have a lot of analog boards already! ;)
Jeg
Quote from: plaxius on December 14, 2017, 07:08:28 PM
///// This is the code ////
//Pgm Timing vars
long previousMillis = 0; // will store last time valuse measured
long interval = 100; // interval at which to Measure values (milliseconds)
unsigned long currentMillis = 0;
//pwm vars
unsigned pwm1; // Value read from A0 to give PWM duty cycle output in terms of 0-5V
unsigned pwm2;// Value read from A0 to give PWM duty cycle output in terms of 0-5V
unsigned pwmSpan;
void setup(){
//Set up PWM
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
//phase/frequency correct mode. SELECT THIS FOR INVERTED OUTPUTS.
TCCR1A = _BV(COM1A1) | _BV(COM1B1) | _BV(COM1B0) ;
// Select mode 8 and select divide by 8 on main clock.
TCCR1B = _BV(WGM13) | _BV(CS11);
Serial.begin(9600);
void loop(){
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
previousMillis = currentMillis;
ICR1 = pwmSpan = map(analogRead(A3),0,1023,100,10);
pwm1 = analogRead(A0); // read duty from A0 for PWM 1
pwm2 = analogRead(A2); // read duty from A2 for PWM 2
pwm1 = map(pwm1,0,1023,0,pwmSpan); // map the duty cycle to the available steps
pwm2 = map(pwm2,0,1023,0,pwmSpan); //map the duty cycle to the available steps
OCR1A = pwm1; // set PWM pin 9
OCR1B = pwm2; // set PWM Pin 10
//////// en code ///////
Use pot in A3 for frequency
User Pot A0 & A2 for DutyCycle
Pin 9 & Pin10 is the output channels
Plaxius, this is a real Christmas gift! Thanks again for sharing. Good work!!! :)
Hoppy
A flurry of interesting posts! The Stiffler polyphase transformer looks a good candidate to what Kapanadze could have been configuring with his 3-phase mains trafo. Does anyone have more info on the Stiffler circuit? I'm feeling this drawing me towards the bench.  :o
