0 Members and 108 Guests are viewing this topic.
peper10
I`ll give you a couple TIPS to think about for now....Any pulsed circuit has his best resonance frequency/ output power in-tune when less resistance is in the collected end.. Any of the power gain in a cap takes TIME to raise at the 80% capacity of a cap so to speak..  Higher values the cap is, more time is needed to fill it.. A 200 volt cap of 200mf has a POTENTIAL of discharge 6amp every second at 200 volts.......  These are all numbers I have found by you guys on this forum....  Now!!   If a joule theif at 12 volts can run at 3.4KHTZ and have spikes of 120 volts, what is the values in mf for a cap to be filled in 1/10th of a second????  When filled ,is it possible to discharged that cap with a voltage divider trough a solid state relay????
Can the discharge of the cap be trough a toroid transformer???  The transformer used to discharge the cap,can it be multi output and be TAPPED TO BE FEEDED BACK TO THE INPUT....  This is just a little layout I present to you to think about...  The simple fact that NONE OF YOU have think past the basic joule theif circuit without any addition is very NAROW VISION..
Grumage
Quote from: Hoppy on December 15, 2017, 04:05:51 AM
A flurry of interesting posts! The Stiffler polyphase transformer looks a good candidate to what Kapanadze could have been configuring with his 3-phase mains trafo. Does anyone have more info on the Stiffler circuit? I'm feeling this drawing me towards the bench.  :o
Hi Hoppy.
Just fired up the PC, I have been following on the iPad.
Remember this? Fitted inside the 2KW Kapanadze aquarium device.
Cheers Graham.
NickZ
   Peper10:
   This is not the Joule Thief thread. There is one on this forum.
   I have suggested that you view Lasersaber's videos on youtube.
Have you done so? If not, you have no ideas what has been tried, and what has not.
   To assume that you know what we have done, you being a new poster here, is precipitated.
   Much has been tested in the last several years. It is obviously you have not read up about what we have or have not done here.
   However, this thread is dedicated to the Dally, Akula, Ruslan, Kapanadze, etz... type of replications. Not the Joule Thief circuits, and similar type low wattage output type of circuits that can basically only light leds, or smaller bulbs, and are not self running.
peper10
Quote from: NickZ on December 16, 2017, 10:47:57 AM
   Peper10:
I dont ASSUME or PRETEND I know.... Al  LASERSABER and TINKELKOALA are in my playlist and  Mr Stanley to named a few... I find that little childish that YOU ASSUMED I have not taked some notes before posting here..  I`m a member here since 2008 or 2009 and same thing on ENERGETICFORUM...   One of my buddy there was INTROVERTEBRATE and he showed me the first experiment I was able to replicate.
The flaw of this forum is not the HEALTHY SCEPTISIM like you mentioned earlier...   It`s the PRETENTION that you need 10 000 000 post to be considered IN THE CIRCLE.  And I dont try to be rude here, it`s just an OBSERVATION I come to after reading all those post that you guys made...  A NEWBEE cannot know more then the HERO MEMBER for sure...  Just let sink it in for a minute..
Void
