0 Members and 150 Guests are viewing this topic.
Jeg
Quote from: plaxius link=topic=12736.msg514387#msg514387 date=1513610784
i try now Arduino Telsa with sync pushpull ...
/quote]
What would be very handy is the ability to chose number of nanopulses, variable frequency and variable width. Arduino zero at 48Mhz can go as narrow as 20,8ns.  Arduino Uno at 62.5ns minimum width.
Void
Quote from: Jeg on December 18, 2017, 06:58:35 AM
Shit!!!  :(
Thanks for describing the incident in case someone will learn from that!
Currently, (last months) i am on Tesla's circuits, learning and fooling around. I see similarities with Ruslan's method but not any OU yet!
Hi Jeg. I think what caused the scope to blow was me accidentally leaving the 1000X scope
probe tip connected to a high voltage point in my circuit when the scope probe's
ground lead was not earth grounded. At those high voltages you should keep the
ground lead on the scope probe earth grounded at all times.
Quote from: AlienGrey on December 18, 2017, 07:05:34 AM
What did you use for the .1uf ? that's a big beast at 10kv
Hi AG. It is a 0.01uF high voltage poly cap rated for 20kV.
It was charging up to around 7.5kV before being discharged by the sparkgap.
Quote from: NickZ on December 18, 2017, 09:23:37 AM
Void:  I'm also sorry to hear about your scope. I know how that feels, as well.
           Have you checked the scope's fuse? It may be a simple fix.  I'm sure Tinsel can also help you if you need it.
Hi Nick. Thanks. It looks like everything is still powering up on the scope, so I think it is probably not a fuse in this case.
The display shows very dimly now. It's probably not worth trying to fix it as I can probably buy a new scope
of the same sort of type for not much more than it would cost to get it repaired by Siglent.
All the best...
T-1000
Quote from: plaxius on December 18, 2017, 10:26:24 AM
Nice Work my Friend .... i try now Arduino Telsa with sync pushpull ...  Thanks for your code. !!!
Is more simple .. open source arduino proyect !!..
Hi,
There is a reason why programmable controllers are not used with Tesla coils with Kapanadze style devices. As soon there will be EMP mode from Tesla coil the ROM eventually is getting wiped so whole circuit stops. Been there, seen electronics freezing a lot...
Cheers!
Jeg
Quote from: T-1000 on December 19, 2017, 04:25:46 AM
Hi,
Cheers!
Hi Arunas
This is very true. I notticed that when using my FG as a driving pulser. The resetable fuse was activating each time the EMP takes place. The problem was due to the common power supply which is shared between all the associated stages. I corrected this by using appropriate filtering to the power supply before each individual board. Seems a good practice as now i don't have this behaviour any more. I used a T-Butterworth filter with two chocks is series and a cap to ground in the mid point.
AlienGrey
Quote from: Jeg on December 19, 2017, 05:39:56 AM
Hi Arunas
it does not stop IMP it will go through anything a metal box it's an acoustic punch it's not a wave, any thing with a micro it will fry ! just wait and see.
I did some work at a test facility they use to blow stuff up you couldn't park your car ant where near it and if it had electronics you couldn't take it in the dam place. No end of radios got fried.
