0 Members and 617 Guests are viewing this topic.
peper10
I think the key theory is ELECTROSTATIC..  There is electrostatic is space ..  The cluster of stars have occasionally Thunder due to electrostatic discharge.. Electrostatic have the same properties of magnetisim and electromagnetisim..  To get it , it require so little effort and you can get in the high voltage so quick.. It`s a conjuncture of both world and the less studied manifestation ....  An ION GENERATOR is a device that require a bit of energy from the source and give high voltage due to it`s ability to play with one side of the 2 parts needed to complete the VOLTAGE POTENTIAL.
Void
Quote from: NickZ on December 21, 2017, 09:58:57 AM
      T-1000:
     So now, it's harvesting ions from gas particles in the air?
   That's not what I was expecting, as the energy source used by free energy devices.
   That's not what Tesla would have suggested, either.
   I guess that this source won't work without air then? Like in space... Or not?  Who knows...
Hi Nick. Keep in mind that is just speculation. Unless someone can demonstrate a test setup that
shows electrons or positive ions or similar being harvested from ionization producing a definite OU effect,
then it is just talk. :)  In the OU experimentation area, the only thing that can actually be trusted is
actual demonstrable bench test results. All else is just talk. :)
I have never come across a statement that came directly from Tesla and which is reasonably verifiable in which Tesla
talked about being able to achieve over unity, or in which Tesla talked about deriving usable energy from the aether.
That is not to say such things are not possible or doable, but just that Tesla never seems to have talked about such things,
that I have come across so far anyway.
All the best...
GeoFusion
Hi Nickz, and All
Ok lecture time. pls take time to digest.
Aether (dark matter) is matter which fills space / cosmos and our very surroundings which also
is still being used to form/create and shape our universe using photons with specific freq ranges and laws.
will not elaborate to much on this.
As it is just only a part of what we are looking for.
What we are looking for and need to comprehend is;
We need to focus on Atoms of Charges and to see them separated.
We have to view the earth's Ionosphere and ground-earth as huge capacitor with split charges.
The  Positron (Ion) (+) / Electrons (-).
Since forever we have seen when lighting strikes happen which manifest this.
We have the Protons which have the electron(-) and we have the anti-proton which has the positron (+).
Earth is (-) ionosphere is (+).
Hydrogen (+) carries positive charges, The sun's Fusion surface is filled with it
and spreading just like any other sun out there which lets us know, space is bombarded with charges.
Earth is simply harvesting it and collected thru the Ionosphere.
Celestial bodies like Earth will then carry negative charges then to make
necessary conditions to electrify most around.
Every planet has it's potential ionosphere if they have.
Now take a look at the Grenade and the Antenna,
Grenade is connected to earth ground (-) charges,
Antenna calling/harvesting/Manifesting the (+) charges (only!)
They are separated in charges.
Tesla coil secondary, when in operation looks like it's shooting lightning (plasma (RF) for solid states)
from it and want's to reach out.
Indeed it has a part of it which reaches out (Corona) but In fact it is calling charges (Ions) from the surroundings.
trying to connect.
It is pulling energy towards it from backround ...
this is caused by spark gap by generating sudden magnetic field and collapses after.
The collapsing of this field is attracting these (+) charges to the secondary and secondary is connected to (-)
which then makes contact and you have lightning!
The beautiful purple Corona which is present on top of Tesla secondaries
when in operation of a spark gap, clearly shows it's vacuuming or trying to harvest the opposite charges (+).
Now to put cherry on top,
With all the electronics for tesla coil or any HV pulse device in right condition
,it's to speed up the process of gathering the charges (+) and quantity and acceleration to multiply amount.
Akula's device with the Inductor (bifilar on the grenade) is to multiply that which  has been harvested
and then overclocked, the speed of process. making a super field.
Series resonance over that part of the grenade could also be seen as a accelerator of the charges (particles).
Example, the spin , just like a delco generator does, needs to reach certain rpm to reach condition.
Balance needs to be searched for,
if you see what you are feeding tesla coil input
and getting effect is small in manifestation, what do you thing you have to do ? ;) think.
The only reason why these devices self run,
is the collected charges coming from backround ( Positrons/ions) in great quantity ( greater than) ;)
which is a external power source then the mains created on earth. (battery /power supply)
in order to make something self run, it needs two separate sources of energy
and in balance for it to be autonomous operation. ;)
Edit** Tesla coil is the Heart of these devices
This is happening with these Akula/Ruslan/Dniester/Kapanadze Devices.
   ~Cheerz
Jeg
Quote from: Void on December 21, 2017, 12:55:11 PM
Hi Void :)
I was always wondering what exactly Tesla meant by his following statement. We know that Tesla is probably behind Ruslan's device which also selfruns. is it safe to assume that by  delivering energy at short intervals can help the machine to sustain its own operation?
Tesla Quote
"..The advantage of this apparatus was the delivering of energy at short intervals whereby one could increase activity, and with this scheme I was able to perform all of those wonderful experiments which have been reprinted from time to time in the technical papers.  I would take energy out of a circuit at rates of hundreds or thousands of horsepower.  In Colorado, I reached 18 million horsepower activities, but that was always by this device: Energy stored in the condenser and discharged in an inconceivably small interval of time.  You could not produce that activity with an undamped wave.  The damped wave is of advantage because it gives you, with a generator of 1 kilowatt, an activity of 2,000, 3,000, 4,000, or 5,000 kilowatts; whereas, if you have a continuous or undamped wave, 1 kilowatt gives you only wave energy at the rate of 1 kilowatt and nothing more.  That is the reason why the system with a quenched gap has become popular.
Jeg
Hi Geof long to see u ;)
Hope everything goes well.
