0 Members and 118 Guests are viewing this topic.
Hoppy
Quote from: NickZ on February 02, 2018, 09:13:15 AM
   So far, I don't see any "extra" output when the Kacher is also on. Just higher draw from whatever is used as the input source. Instead of the other way around.
   If using 100w bulbs, or higher wattage bulbs, my feed back circuit will not power the PS used for looping the device. The feed back PS will only works to produce 24v, when using a load of a single 25w bulb, or other low wattage bulbs.  How about YOU...
That's a lot of losses in the system, which is understandable in conventional terms. There just has to be a fuel involved for the claimed self-running high claimed outputs to be achieved. My hunch is that if not faked, its the yoke ferrite, assuming its the right type.
Void
Quote from: AlienGrey on February 02, 2018, 06:35:32 AM
To help you I have posted a Photo of Adrians Kacha coil that might be of interest to those who are seriously interested in
solving this mystery.
Allen
What makes you think that is copper foil and not magnet wire?
What are you basing that on? Just looking at the picture you posted
you can't tell if it is magnet wire or copper foil. Also, I understand that Adrian
later said his devices were not OU. Why look at someone's devices who it seems did
not demonstrate them in person to anyone and later said his devices were not OU?
It sounds like he may have just been trying to get some attention and then
later changed his mind. :)
Also, I have asked here in the past, and no one could point me to a demo by Stalker
where he demonstrated anything that appears to be OU. It seems he has not made a
demo of any sort of OU. In that case, I don't understand why people keep talking
about Stalker. ;)
@Nick, it is highly unlikely at best that you would be able to self loop a setup if you
are not first seeing a substantial COP > 1.
All the best...
NickZ
   Hoppy.
   When in the best resonant point I can power the feed back circuit, as well as a load bulb.  But, not in the best
RM mode. As the  RM has lower useable output. So far.
   My Li/ion battery pack did not work well so I'm rewiring it now.
   Also trying to buy two new 12v, 7ah batteries, if I can find some. It has not been easy to find them lately.
  While still looking for the missing link to this type of device.
Void:
Stalker is not showing any thing self running any more, And removed the only video that showed his first self runner. And, just removed his latest video, as well. However, he is about the only one posting any videos these days, and describes them also.
  However he has several newer videos out now. But not showing any self running results, on purpose to avoid complications.
  My TL494 and driver circuit is the same or similar to what Adrian was using, which was also a Stalker replication, or version of it.  And that part works as it should.for me so far.
AlienGrey
have another look here the yellow light doesn't help.
note if the primary coil is in the middle the katcher is called bipolar.
Void
Quote from: AlienGrey on February 02, 2018, 01:01:46 PM
Hi AG. It looks like probably magnet wire on the tube, but below the tube
in that picture could maybe be some copper foil however.
All the best...
