0 Members and 123 Guests are viewing this topic.
Sergh
apecore
Quote from: NickZ on February 02, 2018, 09:13:15 AM
   Apecore: What's new with your set up?
Hi all,
Nick, my setup is doing fine, no revelations yet just obtaining the lowest power rate to go IN.
The most important item.  as where it stucks... would be the kacher part
For selfrunning stage.. we do need to lower the power in as low as we can.......  not for final end result but just to see when "back looping" will be working....  when this is reached... probally we are on a right track...
i.e. its more difficult nor almost impossible to obtain selfrunning when the system is needing 10Amps @ 24V
Probally the kacher process ....  transferring/ catalizing the energy to the grenade/ inductor by its antenna is the goal in this in a mayor way.
This is something we have not yet being able to... if someone thinks the RM mode would be this...  then again i would say bring down the input power factor and see what will happens
Until now we only have accomplished a working inductorloop... some HV/HF field effects ....  and burning scopes ;D
We need to discuss this part of the game more.... then turning pots day by day.
What realy would maybe be of help if we would start with doing a assumption of the Mode of operandum......in order to make some progress in the mentioned kacher process
I d like to challenge Void and Hoppy to contribute in this as maybe we should start very simple and lean as normal physics should be.
Of course others are welcome to contribute to.. 100%...always better....
But focus on this item is important in the first place... (this is what i like about some other threads).
People with working setups could provide tests......  in order to verify what is proposed..
What i d like to start with, as i said lets keep it simple at the start is the following;
The grenade is a bifilar coil,....the inductor is generating a magnetic field within the bifilar grenade..
The kacher is (assuming) disturbing this inductor magnetic field and responsible for EMF in the grenade.
Important in this process as i believe is that the magnetic field from the inductor needs to "collaps" entirely whitin the grenade to obtain a significant EMF..  (Right?)
This is something we don't know if thats the case in our setups..
Besides that the whole coil/ FRES tuning wil have a increasing effect on the EMF results.....  as this is probally part of the fine tuning process
Lets assume  or just let us go by this direction......  what does this tell us bout the grenade configuration  (it bifilar shape) .....  and what kind of pulses/ waves we need on the antenna.
T1000 posted longtime ago scopeshots of effects coming from ground by pulsing a grenade..... i wonder if he has some better results yet.
Nick,... if we want to compare results we need also to do the same things with same setups,.. nescessary to find out the missing part(s)
Commitment to do the things as what is supposed ,...  meaning that if Void and/ or Hoppy are willing to contribute in helping with the theoretical part and proposing some testoptions.... we need to do as proposed,...  else it is waiste of time
I think we have some new members with lots of stuff on there bench... and willing to cooperate to find the missing part.
Greetings
Hoppy
Hi Apecore,
As I wrote in my last post, I consider that if the claimed self-running devices are genuine, then a fuel is required and this is more likely to be the ferrite rather than more esoteric forms of energy derived from earth currents or the ether. Therefore, if and when I restart experimenting, I would concentrate on, as it were, stimulating the ferrite core in different ways with various pulsed magnetic fields. However, my hunch is that the composition of the ferrite is important and as I've mentioned a few times, the old barium types used in the 1950's / 60's, may be the most likely candidates. Unfortunately, barium ferrites are difficult to source nowadays, as they have been for many years been replaced by other types of ferrite.
AlienGrey
Are you using an NPN power transistor to drive the katcher ? if so i bet you have the same problem I have had with every one i have tested, they do not turn off, hence the heavy current and get hot. Have you tried using a MosFet  try a IRF 450 or 460 it will work dead good with a low value resister in the gate circuit I did use a feed back winding with my experiment 10 turns  it was excellent if you want to try experimenting with it.
apecore
Quote from: Hoppy on February 02, 2018, 04:35:46 PM
Hi Apecore,
Hi Hoppy,
Yes,...i know.. seems to be a good direction to try it out.
But..  they are still avaiable.
https://www.alibaba.com/product-detail/Y30-barium-ferrite-louder-and-speaker_60672772180.html?spm=a2700.7724838.2017115.1.3c93b095pFHDEv&s=p
See the next link,...even in the discription of these Metglass cores..  they are mention even Free energy applications
https://www.alibaba.com/product-detail/25um-Ribbon-Metglas-Amorphous-C-Core_60480951528.html?spm=a2700.7724838.2017115.42.3c93b095QVfaGo
Greetings
