0 Members and 115 Guests are viewing this topic.
NickZ
  MenofFather:
   I don't know about the choke connection, other than it just goes a tuning cap. But, in the Hendershot information, the coil/capacitor in the center of the big air coil goes to a iron core transformer that is located outside of the air core. Maybe the choke on the akula device also goes to one of the air coils, or maybe even to the yoke through the white wire that is under the choke. Hard to say what is going on. I think that the only way to find out is by testing the results.  I just don't want to connect 110v DC to the yoke direct, yet, but I may give the yoke primary center tap 30 to 50 volts AC to see what happens.  I also will probably hook up my CFL bulb driver circuit to the yoke to see what it does. It should output about 250v volts, or higher.  Any way, that's what I have in mind to do next.
Thaelin
   Pic posted on main TK forum too and now its gone as well. Hmmmm? :o
Guess that points to something there that wasn't wanted to know.
thay
verpies
Quote from: T-1000 on June 08, 2013, 06:16:18 PM
http://www.vykoma.lt/akula.jpg
This is what gone to blank page... Save image for future use because the Lithuanian server might go down as well ;)
Note that this circuit has ferrite cores in all transformers.
No empty air coils - no energy from air (or vacuum).
forest
Quote from: verpies on June 09, 2013, 01:59:34 AM
There should be no difference , except you have to fight with very high frequency and HV if you want the same effect on air cores. It's my personal opinion but I don't think I could be wrong; electricity is one only but the ampere-turns is required.
If you didn't yet realized it's all about Tesla article from 1900 and..... Newton III law  ;D ;D ;D :)
IN other words...how to tap huge potential energy when there is no possibility to go to lower level directly.... Return back to the analogy of huge lake in the mountains....as Tesla described....
MenofFather
Может из-за технических ошибок пропала страница, то выкладываю, что было на ней. http://www.speedyshare.com/x3Bnq/akulac.png
Это схема похожа на настоящую, но тот который её выставил (Сергей), сказал, что не Акула её прислал ему. Поэтому от куда он её взял непонятно.
