0 Members and 174 Guests are viewing this topic.
itsu
QuoteJeg:
   You might want to check Cepren Stalker's last video, where he is showing how to build a 3 inch round sphere.  So, I imagine that a 30cm sphere could be made in the same way.
   I tried to download a link to Stalker's video, but I was not able to do so. Just check it yourself if interested.
As it looks like Stalker may be going the same route, with the HV type Tesla coil "transmitters"
Nick,
good find, indeed, it seems Stalker is building a SSTC too, see his latest video's here:
https://www.youtube.com/channel/UCnKiEDi9e3SyctFmLtczLBg
His diagram looks like the one from this SSTC builder which uses 120V AC as primary input while Stalker seems to use a 12V battery with DC2DC converters.
http://www.loneoceans.com/labs/sstc2/
Itsu
Jeg
Quote from: itsu on February 08, 2018, 04:43:51 AM
Nick,
Itsu
Indeed a good find Nick! I just have first to limit more my input consumption. Hope next days to find some time more for this.
Itsu thank you for the links.  ;)
NickZ
  It will be interesting to see just what Stalker plans to do with that new set up. Other than to blow controlled HV streamers into the air.
  Would the output frequency of the SSTC circuit maybe be too low for the Akula/Ruslan/Stalker device?
As it needs around 1MHz, or even up to 2MHz, or so.
   Has anyone (Geo) connected up a feed back path, to the input side, yet? That will change several things, and make tuning the device, even harder. At least for me, so far. As the feed back circuit PS, is a big load on the grenade's output.
   Jeg and Itsu: Good to see you guys posting, again.
   Jeg, good luck with your tests. I recommend that you try to find a bigger yoke core, minimum 3 inches across.  My yoke is almost 4 inches wide when wound with the coils. Yours all look smaller.
   I remember that Akula could not make the smaller Tv yoke output enough current to self run. On his first try at it. There are also even bigger yokes, on the old 34inch CRT Tv, around 5 inches wide, or so.
It would seam that the bigger the yoke, which uses more copper wire wound on it, (but, the same number of turns) the higher is the output.  Right?  And, you do need a good output to be able self run.
AlienGrey
Fellers has any one ever thought of takin this NMR of copper into consideration ?
When things get excited things happen. With glass it's obvious.
http://triton.iqfr.csic.es/guide/eNMR/chem/Cu.html
NickZ
  Ever thought about poisoning yourself.  Try NMR, it works well for that. Or so I've heard.
  I pass on that one, no need to burn things up to draw energy from. That's not the same thing, as drawing clean energy from the ambient, aether, etz...
  Hoppy might be interested, though. He's looking for a source for NMR to finally start working on.
