0 Members and 675 Guests are viewing this topic.
Quote from: AlienGrey on February 09, 2018, 11:52:17 AM
An EEEE module madewith genuine Bosh parts an R0 and an R10 (EV Grey) spark tube.
If you make one don't forget to earth the center link  ::) 8) ;D
No, it isn't. If you think it is, demonstrate wireless power transfer using it. You cannot.
ramset
Well
AG
I would have to say
Any ideas or suggestions which can show ANY true anomaly on the bench should get a good looking at.
I have never seen sooo much power transferred wirelessly as Tinsel has done  [ talking Horsepower
I believe at some point ??].
will be good to follow this EEEE path of investigation .
and yes even some "atmospheric vacuum" experiments are going to be proposed
Also....lately
you have been posting round about suggestions and links to things here and there ?
respectfully
maybe a bit more info and direction on what you feel is a better path to a true gain anomaly ??
Chet K
Thanks Grandma
Quote from: AGPS re Tinsels Long SA   (http://overunity.com/Smileys/default/grin.gif) did any one notice the bit about 'the self oscillating Katcher circuit it just wont work
because it has to produce a nano pulse because if it's not the current and hence the voltage will destroy any radiant energy reference!.
(sic)
Can you translate that into English please?
And just what is "radiant energy reference"? I have yet to see any coherent definition of the term "radiant energy".
What I _have_ stated is that for best high voltage performance in a solid state "tesla coil" system a coil driver must produce fast rise-fall transitions, the faster the better, and the normal "Kacher" circuit does not do this very effectively. This is a direct consequence of Faraday's Law of induction. "Nano pulse"? Whatever, dude.
It's easy enough to understand what is being shown in the string of videos posted up above. For example the last one is a simple classroom demonstration of Faraday's Law of induction. Some of the others are rather poor demonstrations of the "brovin kacher" using some kind of boogered commercially available driver circuit. It's clear to me that the demonstrator is rather a novice in these matters.
AlienGrey
Yes why not  ( I screwed that up a bit, the cat wanted the WC sorry its a big cat),  yes |Faraday and Tesla talked about the DC voltage being
at the switch,  before the knife switch was closed and once closed a huge 'radiant discharge pulse' would follow 20 to 30 kv,  thus killing the engineers
in the vicinity, Tesla and others worked on that principle that grabbing the voltage before the current reached the switch.
Howe does that sound ? hence the phrase don't destroy the dipole.
So the question arises how the hell did any one get the self oscillating katcha circuit to work with a sine wave in the circuit they all recommended using ?????????????????????????????????
The Tesla Katcher provides the voltage Or should and the ground the current, but don't ask me how i think the rest of it works  ;D all i found was a way to use a MosFet to do the
katcher job  properly as the bipolar NPN does not switch off  I discussed this with Nick a while back.
Allen
Yes, using a mosfet is better than using a bipolar transistor because of its better switching characteristics. Then you can go a step further and use an actual mosfet driver chip to overcome the slowdown due to the mosfet's gate capacitance and really slam that sucker on hard and cut it off fast. Then... another step further, since the signal input to the driver chip is a high impedance input, you can easily rig up a feedback system to provide a signal input to the driver chip that is locked to the resonant frequency of the secondary's "radiant" output, and voila! You've made an autoresonating SSTC that will outperform the Kacher you started with, using the same coil set.
